20 Most Recent
Lakewood 5101 Oil Filled Radiator Heater Questions & Answers
Swich on and of don
They don't make replacemnet parts any more and the company is no longer in business. But you can use any off and on switch you can find that fits in the hole, or rig an external switch. You can also find these heaters on e-bay for parts.
We turned it off and
was the heater still warm when you turned back on the oil is heated by a thermostat control if oil hot heat will not turn back on till cools down these can take a while to cool down as all done by naural ventilation, if this is not the case i would get a service agent tolook at for you
Have a Lakewood HV9 that died.
No. If my memory is correct it has a thermal fuse in the winding that opened. It was not designed to be replaced or repaired. Your berings froze up stalling the motor. It got hot and took out the fuse. You got a lot of years of good service from it.
I need wiring diagram for a Lakewood heater
try this link.
https://images.app.goo.gl/eqouF5WZLpQbu987
There are several diagrams for lakewood heaters.
Youb can also do a search google by typing in (wiring diagram for a Lakewood heater).
