20 Most Recent
GE JRP28 Electric Double Oven Questions & Answers
I have a code on the panel of my upper oven. The
Touch the CLEAR/OFF pad. Allow the oven to cool for one hour. Put the oven back into operation.
Disconnect all power to the oven for at least 30 seconds and then reconnect power.
If problem continues you may have a shorted key panel switch and may need to replace the Control board
2/9/2011 1:53:32 AM •
GE JRP28...
Answered
on Feb 09, 2011
GE oven error code f2
Hi
Thanks for using FixYa. Error F2 in your oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
8/27/2010 3:11:42 AM •
GE JRP28...
Answered
on Aug 27, 2010
Oven Light Will Not Shut Off - GE Range Oven Model: PS968SP1SS
If you have already replaced the Hi-Amp Door Switch on your GE Range Oven (Model: PS968SP1SS), but the oven light still will not turn off, there are a few additional steps you can take to troubleshoot the issue:
- Check the light switch: Ensure that the light switch is functioning properly. It is usually located near the oven door frame or control panel. Press the switch manually to see if the light turns on and off. If it is not working, you may need to replace the light switch.
- Inspect the light socket: Examine the light socket for any signs of damage or corrosion. If the socket appears to be damaged, you may need to replace it.
- Verify the wiring connections: Check the wiring connections between the light socket, the Hi-Amp Door Switch, and the main control board. Ensure that all connections are secure and properly connected. Loose or faulty wiring can cause the light to stay on.
- Test the main control board: As you suspect, a faulty main control board could also be the cause of the issue. You can try resetting the control board by turning off the power to the oven at the circuit breaker for a few minutes and then turning it back on. If the light still does not turn off, it may indicate a problem with the control board that requires replacement.
If you have performed these troubleshooting steps and the light still won't turn off, it would be advisable to contact GE customer support or a qualified technician for further assistance. They will be able to diagnose the problem more accurately and recommend the appropriate solution.
6/18/2023 4:55:39 PM •
GE Ovens
Answered
on Jun 18, 2023
I have a GE rapid clean II J55BF-1 wall mount oven needs to replace the baking element. Did someone happen to know the part number of the replacement baking element ?
To find the correct replacement baking element for your GE Rapid Clean II J55BF-1 wall mount oven, you can try the following steps:
- Locate the model and serial number of your oven. This information is usually found on a label on the inside of the oven door or on the back of the oven.
- Visit the GE Appliances website or use an online appliance parts retailer to search for the part using your oven model number.
- Look for the baking element part number in the oven's user manual or service manual. These manuals may be available online or from the manufacturer.
- If you are still having trouble finding the correct part number, consider contacting the manufacturer's customer service department for assistance.
Once you have the correct part number, you can order the replacement baking element and follow the manufacturer's instructions for installation.
2/26/2023 11:58:18 AM •
GE Ovens
Answered
on Feb 26, 2023
