20 Most Recent
GE JKP20 Electric Single Oven Questions & Answers
Why oven cools automatically after preheat
Others are having problems with this unit. Have the manufacturer support their product and fix it. It should be covered if it is new. Don't delay in hounding them. Time will expire and you will be left with an expensive ordeal.
11/2/2013 6:35:39 AM •
GE JKP20...
Answered
on Nov 02, 2013
I have to turm the oven off at the braker box. it
This is usually a keypad stuck key error, usually caused by a bad keypad or sometimes caused by your control board.
F7 usually means a stuck key on the keypad. I've also seen it caused by a greasey buildup on the keypad connector into the control board. Try pressing each button on the keypad followed by cancel. See if the buttons are registering with the control - should get a beep or some function (execpt up/down buttons need a cook or time function enabled first). If one of the buttons seems inoperative it may be stuck, in which case you probably need a new keypad.
Best Regards,
Diana
6/16/2010 4:55:50 PM •
GE JKP20...
Answered
on Jun 16, 2010
My ge specta bottom heating coil is not working.
I just took apart mine and found the same problem. Broil and range work fine but nothing when the bake function is used. I pulled the heating coil and it showed open (infinite resistance). This could well be your problem too. Pull out the drawer on the bottom and you'll see where the coil connects. Pull it and check resistance with an ohm meter. If it shows open, that's probably your problem. It was pretty easy to pull and shouldn't be too tough to reconnect either.
12/25/2009 4:57:44 PM •
GE JKP20...
Answered
on Dec 25, 2009
Oven comes on for no reason followed by the start beep
yes you can kill the power and lock out the box with a pad lock for safety. the panel is attached by screws usually on the bottom of panel. lower and seperate the control panel ribbon from the erc (electronic range control). without removing any other components leave ribbon loose and replace panel. turn power back on. if the beeping does not recur, the control panel probably has a stuck key. if it does resume the erc is faulty
5/17/2009 11:56:38 PM •
GE JKP20...
Answered
on May 17, 2009
Oven turns on by itself
only thing i could say here is replace the control or clock its real name is an eoc electronic oven control now the part is under a five year warrenty but you have to pay labor and use some one that is authorized for ge warrenty work check your owners manuel for second to five year warrenty and go to ge web site to locate servicer in your area
http://www.geappliances.com/service_and_support/service/
6/5/2008 4:27:43 AM •
GE JKP20...
Answered
on Jun 05, 2008
