20 Most Recent GE ZSC2001FSS Advantium Electric Single Oven Questions & Answers
GE Advantium Microwave portion not working
There is a fuse for the Hi voltage transformer and the magnetron tube. You have to take the cover off to access the fuse.
9/2/2017 8:18:21 PM • GE ZSC2001FSS... • Answered on Sep 02, 2017
Replace outside glass
You have an expensive Monogram microwave so you can expect the parts to be expensive also. The outer glass assembly by itself ballpark cost is about $160 and requires a complete dis-assembly of the door to replace since the screws are all inside. Then if you go by the book--- the door should be checked for microwave leakage after the repair which requires a special test meter. They also sell a complete door assembly at around $300 that comes completely assembled. You need to compare that cost against the age of your microwave and possibly a new unit which I think is still available. Either way its not a cheap fix.
6/4/2015 4:18:05 AM • GE ZSC2001FSS... • Answered on Jun 04, 2015
0answers
2answers
Ge profile advantium 120, scb1001 oven, display panel out
My GE Profile Advantium120 interior lighting it out .What do i do to replace these bulbs.
6/28/2012 12:55:09 AM • GE ZSC2001FSS... • Answered on Jun 28, 2012
I am getting arching in the oven when the only
Hello, thank you for posting your question on Fixya. I will be helping you with your Advantium oven. From your description it sounds like your having problem with the oven arcing. While you are using your microwave you can only have arcing occur while you are using the microwave or speedcook feature. While in either mode attention must be given to any mental in the oven. When microwaving place food and containers on the white ceramic tray only. The metal pan should be used during speedcook.
Happy Holidays!
Please rate "4 thumbs" if this was helpful.
12/23/2010 6:04:56 PM • GE ZSC2001FSS... • Answered on Dec 23, 2010
Microwave
Hi my GE Advantium oven is displaying an error message and beeping. The Error is F3. Could you please help me with this.
7/3/2010 5:36:43 PM • GE ZSC2001FSS... • Answered on Jul 03, 2010
2answers
The GE Profile Advantium SCB2001KSS
F3 This code usually means that the oven sensor needs to be replaced.
Good luck
Please rate FixYa!
9/22/2009 8:45:28 AM • GE ZSC2001FSS... • Answered on Sep 22, 2009
I need to replace my
You may have to disassemble the door to get to it. Are you sure this is not a double paned glass and it is 2 pieces of glass in one assembly?
1/30/2009 11:11:47 PM • GE ZSC2001FSS... • Answered on Jan 30, 2009
I need to replace the outer glass on my Advantium oven
contact GE; they should have replacement glass in stock.
1/15/2009 6:43:10 PM • GE ZSC2001FSS... • Answered on Jan 15, 2009
Advantium zsc2001fss no power no lights
I have same unit...power outage made unit come back on and it then requested user to set the clock, but the display shows the hours but won't accept the pushputton to lock it in. I had to look at the control panel today to see how hard it would be to replace.
To take off the front vent panel: first take microwave out of the built-in space, disconnecting the power cord. Then the top outer metal skin can be unscrewed and removed, which exposes the screws that hold in the front top vent and the control panel in place.
8/8/2008 7:16:31 AM • GE ZSC2001FSS... • Answered on Aug 08, 2008
Advantium without power
Check http://www.applianceaid.com/erange.html, maybe you can find some info to give an idea where to check.
If not power is circulating through it, I would suggest to check the fuses inside the appliance first. Make sure you disconnect it from the main power before attemping to remove and check the fuses.
2/21/2008 11:57:07 PM • GE ZSC2001FSS... • Answered on Feb 21, 2008
Unit has no power.
I know what you mean. I was cooking with this appliance tonight and suddenly it displayed an f-3 code. My advantium oven is less than 8 months old. Not sure how this happened or how to fix the problem. In order to sleep tonight (the constant beeping) I had to shut power off at the breaker pannel. Is this representative of the the type of quality that GE stands for???? I am sooo frustrated. I cook with my advantium oven all the time and love the dual abilities of this appliance. Like I said this is brand new and to have the f-3 code which apparently (from what I read) is a failed key pad. I am very dissapointed and am begining to think about pulling my stock from this company!
2/21/2008 2:31:16 PM • GE ZSC2001FSS... • Answered on Feb 21, 2008
Door is loose
12/26/2007 3:10:48 AM • GE ZSC2001FSS... • Answered on Dec 26, 2007
Why does it say "Clean Door" during the self-cleaning procedure?
Never ever use the Self Clean feature. All it exists to do is to keep the makers in a steady stream of sales of spares. The temperature is 800 to 925'F. The parts can't handle it. Try turning off at the breaker overnight to reset.
Why You should Never Run A Self Clean Oven Cycle & A ...
General Appliance Service https://www.generalappliancesvc.com > why-you-should... Jan 29, 2020 - A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 F° or ...
Self-cleaning oven
Wikipedia https://en.wikipedia.org > wiki > Self-cleaning_oven A self-cleaning or pyrolytic oven is an oven which uses high temperature (approximately 932 °F (500 °C)) to burn off leftovers from baking, without the use ... ‎Pyrolytic process · ‎Alternative technologies · ‎Catalytic cleaning
Self-Cleaning Oven: 6 Reasons to Stop Using Feature ...
FIX Appliances CA https://fixappliances.ca > 4-reasons-stop-using-self-cleani... Feb 2, 2024 - Auto-cleaning, also known as "pyrolytic cleaning," operates by heating the interior of the oven up to 500?C. During this process, grease is ... ‎How Self-Cleaning Ovens Work · ‎Major Parts Damage ..
2/27/2024 4:13:13 AM • GE Ovens • Answered on Feb 27, 2024
GE Double Oven. How do I remove the front glass so I can clean the inside of glass
You remove the door and then split the inner and outer parts of the door. clean the glass with Easy Off spray, rinse well, polish and put it back together. The videos should help as they all work to a theme.
How to Clean Oven Glass-Inside, Outside, and In Between!
The Happier Homemaker https://thehappierhomemaker.com > Recipes > Cleaning Aug 24, 2022 - Spray outside glass with vinegar and wipe down with paper towels. · Clean inside of the oven glass with a scouring pad using the "hack" below. ..
11/24/2023 7:51:22 PM • GE Ovens • Answered on Nov 24, 2023
GE ZSC2001FSS Advantium Electric Single Oven Logo
26 questions posted
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Ovens
  • GE Ovens
Most Popular Question
need user manual
  • Ovens
