20 Most Recent GE Profile JT955 Electric Double Oven Questions & Answers
I have an FA code as well. Dont know what it is. Everytime it comes on I clear it and it comes back. Not using oven, just cook top
GE Profile JT955... | Answered on Sep 19, 2019
Bad oven temp sensor. If you know how to do so you can disconnect the power and remove the temp sensor. The two white wires to the sensor, ohm it. it must read ~1080 ohms. If not really close to that at room temp then replace sensor.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
GE Profile JT955... | Answered on Dec 11, 2013
The first thing to try and do is to just "kill" all power to the unit for a while, at least 2 minutes, to see if we can kick-start the elements. Hopefully it's just a temporary glitch that is preventing them from starting up. Try shutting off the circuit that controls the oven, at your circuit breaker. Just flip it off for a good 2 minutes or more, then flip it on. Try that and then attempt to run the ovens to see if it makes a difference.
Let me know what you find, in the mean time I am researching this further for you, just reply here..
Thanks,
Tim
GE Profile JT955... | Answered on Oct 28, 2010
that this code indicate is that there been an over flow of water(liquid substance) in to the pane of the oven.
What you are to do to fix up this problem is first put off the power supply connected to the oven then unscrew the screws from the back with a screw driver,then trace the wire down to the panel then carefully clean up all form of dirt you can fine around the panel then couple it back ,with this the problem is solve
hope this help?
Thank you and thanks for using fixya.
GE Profile JT955... | Answered on Sep 19, 2010
Hi
Thanks for using FixYa. F1 error indicates that the control board (ERC) has gone bad and the electronic range control (ERC) should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
GE Profile JT955... | Answered on Aug 27, 2010
if its an f-7 error code its due to a stuck error code
GE Profile JT955... | Answered on Feb 07, 2010
F7 means a stuck button on the membrane pad. You may have to replace the membrane switch pad
GE Profile JT955... | Answered on Aug 06, 2009
GE Profile JT955 Electric Double Oven Logo
Popular Tags
22 questions posted
Top GE Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Ovens
  • GE Ovens
Most Popular Question
fa function error ge profile stove
  • Ovens
