Door switches
If one of the door interlock switches
is not switching properly or there is a condensation problem on the
sensor control panel, either can cause the turntable/light/oven to
come on even though the "Starts" button has not been
depressed due to the wiring of the switches.
Check for faulty door
switches and/or contaminated actuators.
I hope that helps.
Door catches.
One of the latches may have broken off or got stuck and
is not lifting the dother latch clear of the housing. Remove from any
power source, remove the cover of the cabinet. Slacken off the clamp
mechanism and ease the clamp over the guide to allow the door to
open. When a new door lever is in place, the door may be easily
adjusted by slackening off the screws that clamp the door
catch/actuators in place whilst holding the door closed and then
tightening the screws. The rear of the door may be adjusted by
slackening the lower door hinge screws and adjusting as required.
I
hope that helps.
29 questions posted
3,405 Questions
567 Questions
285 Questions
308 Questions
257 Questions
