20 Most Recent
GE JVM2070 Microwave Oven Questions & Answers
The vent fan does not draw air from stovetop
There is a wire mesh filter and a carbon filter on the under side of the unit. IF they are plugged then it wont draw air. The other issue is this unit has a dual option for installing the fan. One is to vent to the outside and the other is to vent to the inside, if the fan is not installed for the correct usage, you have no airflow either.
I need to replace the
1. Unplug the microwave
or turn off its breaker.
2. Open the door, then
detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without
disconnecting the wires.
If you have any trouble getting the grille off once the
screws are
removed, slide the hood vent grille to the left about 1/4", then then
pull it forward.
On some models there are L-shaped clips that fit
into a slot to hold bottom of the vent.
You can find helpful
exploded view diagrams and order parts by entering your full model
number here.
They're our favorite supplier.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
Keypad not working
Then just replace the keypad they stick on like a sticker and the ribbon part of it plugs into the control board
11/30/2013 11:38:16 PM •
GE JVM2070...
Answered
on Nov 30, 2013
Fan running
measure this test and use the multimeter for fix it. GOD BLESS YOU
- Exhaust fan motorIf
your exhaust fan motor is not running, there are a couple of things that
you can check involving the motor to locate the problem. After removing
the fan motor, you can manually attempt to turn the fan blades with
your hand. If the fan motor is working properly, the blades should spin
effortlessly. If this does not occur and the blades are taught, the
motor will need to be replaced. Secondly, the fan motor itself can burn
out due to time and usage. Using an ohm meter, the exhaust fan motor
should read open for continuity. If it does not, then the fan motor has
expired and will need to be replaced.
- ThermostatAnother part
that could cause the microwave exhaust fan to not work is a faulty
thermostat. A thermostat gauges the air temperature, which activates the
exhaust fan when required. If this part becomes flawed, the exhaust fan
will not energize and the thermostat will need to be replaced.
- Main control boardIf
your exhaust fan is still not working and the microwave fan motor,
wiring, and thermostat are operating accurately, the root cause could be
with the main control board. Replace the main control board.
Fan starts when i open door
follow this test and use the multimeter and fix it. God bless you
