20 Most Recent GE JE1860 Microwave Oven Questions & Answers
0answers
Won't turn on!
Be the first to answer 4/8/2014 4:55:04 AM • GE JE1860... • Posted on Apr 08, 2014Be the first to answer
0answers
Bad door switch
Be the first to answer 3/20/2014 4:16:31 AM • GE JE1860... • Posted on Mar 20, 2014Be the first to answer
manual
3answers
Sparking on right side of the inside of the
If there is spark please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is leaking and sparking to the ground. As you have mentioned it was stored, it is quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Now switch the microwave power on and use a cup of water to test. If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. Replace with same type. If not check the waveguides within the cabin for food particles that can burn and spark, check for rust that can corrode and spark when the ceramic paint has worn out. If there is heating without any issues, you can use the microwave safely
10/17/2011 12:33:30 PM • GE JE1860... • Answered on Oct 17, 2011
HELLO. I HAVE A GE
The F3 code means that the Key panel also called touch pad is shorted. This code usually comes up when when the Microwave detects the shorted panel continuously for over 60seconds.
To correct this error, you have to Replace the key panel also called the touch pad.
Thanks.
9/14/2011 5:04:52 PM • GE JE1860... • Answered on Sep 14, 2011
Condensation has formed in the
there is nothing you can do for two reasons 1 - there is a special film behind glass 1 that stop radiation from leaking if the seal is broken then the machine will be dangerous 2 - there are aprox four film layers to get throught to clean the front panel simply put it out in direct sun for a couple of days and the mist will dissapate
take care
sonic boom australaia
7/11/2011 11:52:42 AM • GE JE1860... • Answered on Jul 11, 2011
Microwave JE 1860 has been
Unless your personally attatched to this oven I would recomend you start shopping for a new one. Take the cover off and look for any fuses inside the front door area or on the control board, If they are bad replace them if none there then get a new one as they are more expensive to repair than replace. Most likely your magnatron shorted out and took the circuit with it, but check your house fuse as well on that circuit to be safe. A magnatron runs around 90bucks part only.
7/1/2011 4:43:22 AM • GE JE1860... • Answered on Jul 01, 2011
Our microwave shows a flashing
Hello & Welcome to FixYa
If you have already tried to leave it unplugged for 15 minutes then the problem is with the control board that needs replacement. You can also check the fuse before replacing the electronic control. Please get back to me if you have any other questions.
Kevin
4/28/2011 1:14:56 AM • GE JE1860... • Answered on Apr 28, 2011
Everything works except that I
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
3/12/2011 1:29:45 PM • GE JE1860... • Answered on Mar 12, 2011
0answers
We have a ge 1860
Basic Microwave Oven Troubleshooting Tips
heatman101
]0]0]0]0]0]0]0]0]0]0]0]0
2/25/2011 3:42:52 PM • GE JE1860... • Answered on Feb 25, 2011
My GE Profile JE1860 is making a noise and not
Basic
heatman101
\00\\\\\\\\\\
2/22/2011 3:44:22 AM • GE JE1860... • Answered on Feb 22, 2011
It is behaving as if there is no power to the
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should start working again
2/11/2011 1:06:59 AM • GE JE1860... • Answered on Feb 11, 2011
GE JE1860 Microwave Oven Logo
67 questions posted
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Microwave Ovens
  • GE Microwave Ovens
Most Popular Question
sparking right side inside
  • Microwave Ovens
