20 Most Recent
GE JEM31 Microwave Oven Questions & Answers
How do you remove cover ofJEM31 microwave
Take the glass plate out, turn it up side down and see if you find 4 or more screws on the four corners of the bottom, but not the ones in the center of the chassis(metal sheet of the bottom) those are holding the fan and other eletronics.
4/30/2014 1:31:48 AM •
GE JEM31...
Answered
on Apr 30, 2014
Spacemaker II Microwave problem
Quite often this is due to a bad door switch.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
7/20/2013 11:58:39 PM •
GE JEM31...
Answered
on Jul 20, 2013
Ge jem31sf01
One of the most common problems like the one you're having & is an inexpensive option to replace is the door switch, replace it and see if that helps. Should be about $10.00. If that doesn't fix your problem, buy a new micro for about $50.00
7/2/2013 10:56:17 PM •
GE JEM31...
Answered
on Jul 02, 2013
Jem31 no heat
The problem is in the magnetron or the inverter board if under 7 years old. Cost to repair will be equal if not more than a new microwave oven.
4/5/2012 12:07:01 PM •
GE JEM31...
Answered
on Apr 05, 2012
