20 Most Recent
Rinnai Vent Free Gas Heater/: 6,000 BTU RCE-229A Questions & Answers
Rinnai 82dfb
I am thinking that the retailer is not up to scratch with gas regulations and gas heater designs and standards
IT might be better if you talk with an accredited gas fitter and clarify what the regulations and standards are applicable to installing gas heaters in homes
Failing that you can get information from companies like origin ( or like company in your state ), and other gas suppliers some of whom sell approved heaters for homes
MAXI hEAT CERAMIC HEATER CH 110
Possible problems:
Adjustable thermostat dirty or worn out. Can bypass thermostat with a wire, if you do this thermostat will not function since it has been bypassed.
"Too hot safety piece" (located between large yellow and large white wire) is dirty between contacts. Disassemble, clean with sandpaper, reassemble.
Rinnai Avenger 25TR Model Gas Heater
I just fixed this problem for my parents. All you have to do is hold the up and down arrows that sorround the power buttom for 3 seconds at the same time and the key symbol should dissapear and make a slight beep. Then you should be able to use the heater as normal =]
My rinnai rce 229 will only start on timer button
To cancel the ON TIMER here's what you need to do:
Press the "ON Timer" button or press the "ON-OFF" button.
The setting will be canceled and the timer indicators will go out.
TO RESET THE UNIT
The ON Timer will be canceled if the power plug is removed from the power point, a power failure while
the appliance was in standby mode, or if the ON Timer setting is canceled. "00" will flash on the digital
monitor when power is reinstated. Pressing the ON button and starting the unit will delete the =00".
Hope this helps you.
Hi there, looking for help
I am unclear whether you have problem with the rinnai gas heater or the hot water system.
Assuming it is the gas heater refer page 10 of
this manual which might be close enough to your model and try the remove air from gas supply procedure. Hope this helps.
If water heater then please provide make and model number.
