20 Most Recent KOBO, INC Kobo Arc 16GB Questions & Answers
General motorcycle tips and advice:
1/25/2024 5:09:54 AM • Work Safety • Answered on Jan 25, 2024
2answers
What was a gas mask?
The gas mask is a mask used to protect the user from inhaling airborne pollutants and toxic gasses. The mask forms a sealed cover over the nose and mouth, but may also cover the eyes and other vulnerable soft tissues of the face. Some gas masks are also respirators, though the word gas mask is often used to refer to military equipment (e.g. field protective mask). The user of the gas mask is not protected from gas that the skin can absorb. Most gas mask filters will last around 24 hours in a nuclear biological chemical (NBC) situation. Airborne toxic materials may be gaseous (for example sulfur mustard and chlorine gas used in World War I) or particulates (such as many biological agents developed for weapons such as bacteria, viruses, and toxins). Many gas masks include protection from both types. Gas masks are used in construction to protect against welding fumes, in deconstruction to protect against asbestos or other hazardous particles, and in the chemical industry when handling hazardous materials, as in making repairs to leaking equipment or cleaning up after spills; workers have usually issued gas masks as a precaution against leaks. During demonstrations and protests where tear gas or CS-gas is employed by riot police, gas masks are commonly used by police and demonstrators alike. Aside from serving their functional purposes, gas masks are also used as emblems in industrial music, with the most notable example, the subgenre of drum and bass called Neurofunk. These emblems are used by graffiti taggers because the mask protects them from the paint canister's toxic fumes, and by urban explorers venturing into environments where hazardous materials, such as asbestos, may be present.
6/14/2023 12:03:04 AM • Work Safety • Answered on Jun 14, 2023
Can I change the address after payment is done?
Yes, You can change.
4/20/2021 11:01:21 AM • Work Safety • Answered on Apr 20, 2021
What is a potatoe peeler?
A peeler (potato peeler or vegetable peeler) is a kitchen tool consisting of a slotted metal blade attached to a handle that is used to remove the outer skin or peel of certain vegetables, often potatoes and carrots, and fruits such as apples, pears, etc. A paring knife may also be used to peel vegetables. A peeler differs from a knife in that the blade has a slot cut into it, which is sharpened on the inside edge, while the other side prevents the blade from cutting too far into the vegetable.
4/20/2021 10:49:18 AM • Work Safety • Answered on Apr 20, 2021
There is a lever on the side of fire place. does it need to be up or doen when you use fire place
That lever operates the iron plate which goes from vertical to flat to shut off the flow of air up the chimney. When the fireplace is not in use, it needs to be closed to prevent drafts or air flowing in or out the chimney. It must be open to use the fireplace. Look up inside to see if you see daylight for it to be open. If it is not open when you build a fire, the smoke will come out into the room instead of going up the chimney.
3/29/2021 6:38:49 PM • Work Safety • Answered on Mar 29, 2021
What is a fowl
Fowl are birds belonging to one of two biological orders, namely the gamefowl or landfowl (Galliformes) and the waterfowl (Anseriformes). Studies of anatomical and molecular similarities suggest these two groups are close evolutionary relatives; together, they form the fowl clade which is scientifically known as Galloanserae (initially termed Galloanseri). This clade is also supported by morphological and DNA sequence data[3] as well as retrotransposon presence/absence data.
4/10/2017 5:27:30 AM • Work Safety • Answered on Apr 10, 2017
How to change the codes of safety box
To remove a number or letter from the code, use the code change tool to push in the grooved button by the number you wish to unset. Turn 180° until the button pops back up completely and the arrow points in the OFF direction (towards the locking pin). Return the white plastic card over the back of the lid.
3/30/2017 10:54:48 AM • Work Safety • Answered on Mar 30, 2017
How to upload products
How to upload products - While listing products on Amazon is a great way to sell your products and expose them to millions of customers, adding multiple items to your merchant account can be a time-consuming process. Instead of adding products one-by-one, sellers with Pro Merchant Subscription accounts can use Amazon's tools to upload product details in bulk. 1. Download Amazon's pre-built inventory file template from Amazon.com that fits your product category. This template is a Microsoft Excel file. You can use free programs such as Apache OpenOffice Calc and LibreOffice Calc to open and edit the file if you do not own Excel. 2. Open the template in a spreadsheet program. Each template has detailed instructions specific to your product category at the top of the document. Carefully read the instructions before entering your product details so you do not make any mistakes. 3. Print the "Data Definitions" tab in the spreadsheet. This worksheet includes important details on the acceptable values and formats you can enter into the template. Keep it handy as a reference when filling out the template. 4. Add your inventory items to the template. Pay close attention to template columns to make sure you enter product details in the correct cell. Enter details such as SKU, product ID, title, brand, manufacturer, description and more. You can also add bullet points to expand on the description of your item in the cells labeled "BulletPoint1," "BulletPoint2," "BulletPoint3" and so on. 5. Save the file in the .xls format when you are finished entering product details. In Excel, OpenOffice Calc and LibreOffice Calc, select "File" from the program menu, then click "Save As." 6. Save the file again as a tab-delimited .txt file, per Amazon's instructions. This is the file format needed for uploading on Amazon.com. If a dialog pops up that says the file format does not support files containing multiple worksheets or something similar, click "OK." If another warning says the document contains features incompatible with the file format, click "Yes." 7. Log in to your Amazon seller account. Click "Upload multiple items," then select the template type for the file you want to upload. To completely replace all of the items in your inventory, select "Purge and Replace." 8. Click "Select File Upload," then "Browse." Locate your product file on your computer using the dialog box, select it, then click "Upload Now." After you upload the document, the page shows the status of the upload. Refresh the page to see the upload progress. Files over 5MB may take several hours to process.
3/30/2017 10:27:23 AM • Work Safety • Answered on Mar 30, 2017
Do hiking boots work in the snow?
Mostly no, if what you mean is will they keep your feet warm and dry. They are not water proof, unless specifically stated, and they are not adequately insulated. What you want are PAC boots, Heavy leather and rubber boots with a felt inner boot.
3/5/2017 2:59:48 PM • Work Safety • Answered on Mar 05, 2017
Ask for replacement for broken eye glass protector
You could try to get new safety glass like the ones seen here. Radnor Motion Series Safety Glasses With Black Frame Clear Polycarbonate...
2/23/2017 8:33:56 PM • Work Safety • Answered on Feb 23, 2017
How do I remove color bleed from white clothes
If the bleed is not to bad you can bleach it out
2/2/2017 7:34:09 PM • Work Safety • Answered on Feb 02, 2017
2answers
Do bullet proof vests provide protection against rifles?
Bullet proof vests normally provide very little to no protection at all against bullets fired from rifles (like the M4 carbine 5.56mm or AK-47 7.62mm). They only provide protection against bullets fired from all hand guns.
10/15/2016 6:56:08 PM • Work Safety • Answered on Oct 15, 2016
tip
The Legality of carrying a police baton
In most countries it is legal for law enforcement and military officials to carry. For a civilian to carry a police baton varies from country to country. Within the United states the laws regarding carrying and pocessing a police baton change from state to state. In some states like Vermont and Arizona one is able to legally carry a baton if you don't have criminal intent or unlawful behaviour. On the other end of the spectrum states like California prohibit the carrying of any club like weapons by a civilian. In the UK the prevention of crime act of 1953 prohibited the carrying of batons in a public space because they are objects that are adapted for causing harm to another person. The UK also has laws about the manufacturing, selling and importing batons. Probably one of the most leanient countries in regards to carrying police batons is Canada. They have no laws against carrying a baton in a public area so long as it is not spring loaded or being carried consealed. While in Sweden one is permitted to own a baton so long as they don't carry it in a public space if they are a private citizen.
on Sep 24, 2016 • Work Safety
I am making a circle vest and one of the abbreviations is fpdc
bulletproof vests,body armor,?A,Goggles,Helmet,Face Mask http://bodyarmoritems.com/products/body-armor/uocc-plate-carrier/c-4
6/14/2016 1:41:59 AM • Work Safety • Answered on Jun 14, 2016
3answers
Do safety protection gloves have to be made out of leather?
No - safety gloves can be made out of many different materials such as; leather, cotton, synthetic, latex or pvc. It really depends what they are needed for.
10/20/2015 8:01:47 AM • Work Safety • Answered on Oct 20, 2015
Echo boots sole disentgrating
If you go to an ecco store they can provide you with a bag and paper to fill out and you can send them back to ecco and have them resoled. It's really not that expensive when you think about the cost of the ecco.
7/27/2015 11:15:25 AM • Work Safety • Answered on Jul 27, 2015
2answers
What is an expandble baton?
Expandable baton, as an impact tool, can be used to strike, jab and block and to aid arm locks. To open, you simply flick your wrist quickly to expand it to it's full size. To close, you simply slam the baton straight down on a hard surface like the floor or a table For more information: http://www.weapons-universe.com/Personal_Defense/Expandable_Batons.shtml
7/27/2015 10:30:25 AM • Work Safety • Answered on Jul 27, 2015
Where can I buy a pair of electrical safety gloves?
Try the Reece Safety website - they have a good amount of electrical safety gloves in their range;
http://www.reecesafety.co.uk/Electrical%20Safety%20Gloves.htm
6/17/2015 12:37:20 PM • Work Safety • Answered on Jun 17, 2015
How do i seal the children's arriot boots to stop them from damage. Not made from leather but they were not cheap.would appreciate any help.need to make water proof if possible.Hoping for at least one
mink oil. small jar only cost's about 5-8 dollars depending on where you find it. i bought my last jar at a Blue Seal. they make other oils but i was recommended this particular kind by a few others and was not disappointed. Caution: allow time to set before using after initial application. the material needs time to soak it in. depending on how often you wear the boots the small jar should last you a good while.
2/21/2015 6:23:32 PM • Work Safety • Answered on Feb 21, 2015
Are there Flame resistant jeans and how much do
Yes there are! and I found this on-line store: http://workingperson.com/workwear-1/flame-resistant-clothing/flame-resistant-jeans.html They cost around $60
2/2/2015 3:33:41 PM • Work Safety • Answered on Feb 02, 2015
KOBO, INC Kobo Arc 16GB Logo
3 questions posted
Top KOBO, INC Work Safety Experts
zulfiqar ali
Drerangula Siva...
Drerangula Siva...
Level 1 Expert
Jaytie Steers
Jaytie Steers
Level 1 Expert
Are you a KOBO, INC Work Safety Expert? Answer questions, earn points and help others
View Most Popular
  • KOBO, INC Work Safety
Most Popular Question
baton open
  • Work Safety
