20 Most Recent Individual SlideShow Expressions Questions & Answers
2answers
Please tell me how do
You need to right-click on any of the inserted photos when in edit mode. Go to "Background color" and choose from the palette. Here you can also choose to apply this colour to the rest of the photos in the chapter, or you can have a different coloured background for every photo if you wish.
11407336
4/20/2022 3:09:54 AM • Individual... • Answered on Apr 20, 2022
I recently bought SlideShow Expressions to do a
I haven't encountered this problem myself, but maybe I can offer some assistance. Make sure that your computer meets all the requirements for the software (given on the box). According to the User's Guide (section 3-3), the following music formats are supported: mp3, wma, wav, ra. I recommend contacting Individual Software's technical support people. You have to register your product to be able to get help, but it is free and could be worth it: individualsoftware.com. From: 11407336.
3/6/2020 11:51:43 AM • Individual... • Answered on Mar 06, 2020
I am working with Arc
To: hspector10
Yes, it seems that SlideShow Expressions specifically has problems with some downloaded music files. You can read about it, and try to find a solution, at Individual Software's website (also try their free online technical support):
http://www.individualsoftware.com/support/frequently_asked_questions.html
3/6/2020 11:31:48 AM • Individual... • Answered on Mar 06, 2020
2answers
Can;t get the software to write the slide show to
Two things: 1. Make sure that you chose the writer drive (burn to DVD) and not "hard drive" in the options window that appears when clicking on "Produce" and then on "Burn to disc". 2. SlideShow Expressions can develop problems when the photos are too large and when the project your trying to burn is quite large as well. What is too large? I can only speak from own experience. I found that once a project gets into the range of 400 or more photos (total) my writer fails to write. (I've burned projects containing up to 388 successfully; photos at original size) However, this can be solved by resizing your photos. I have a project with 466 photos (10 chapters) that wouldn't burn to disc. I then resized the photos so that every single one was under 500 KB. It worked: burning is now successful. Resizing doesn't necessarily mean that the quality of your photos will drop. I used Microsoft Office Picture Manager and, really, visually there is no difference between the original photos and the resized photos in the slideshow project. Experiment with photo size. Maybe another size works for you. It is also known that chosing the archive option (having the original photos and music burned to the disc) can upset the burning process - but only really when it's a very large project. Also, you could be using the wrong type of disc. Try DVD+R.
11407336
2/16/2020 6:41:44 AM • Individual... • Answered on Feb 16, 2020
2answers
After trying for over 12 hours, we can't burn the
Two things: 1. Make sure that you chose the writer drive (burn to DVD) and not "hard drive" in the options window that appears when clicking on "Produce" and then on "Burn to disc". 2. SlideShow Expressions can develop problems when the photos are too large and when the project your trying to burn is quite large as well. What is too large? I can only speak from own experience. I found that once a project gets into the range of 400 or more photos (total) my writer fails to write. (I've burned projects containing up to 388 successfully; photos at original size) However, this can be solved by resizing your photos. I have a project with 466 photos (10 chapters) that wouldn't burn to disc. I then resized the photos so that every single one was under 500 KB. It worked: burning is now successful. Resizing doesn't necessarily mean that the quality of your photos will drop. I used Microsoft Office Picture Manager and, really, visually there is no difference between the original photos and the resized photos in the slideshow project. Experiment with photo size. Maybe another size works for you. It is also known that chosing the archive option (having the original photos and music burned to the disc) can upset the burning process - but only really when it's a very large project. Also, you could be using the wrong type of disc. I've been using DVD+R.
11407336
2/16/2020 6:40:05 AM • Individual... • Answered on Feb 16, 2020
2answers
I receive "Failure writing to disc" message as I t...
SlideShow Expressions can develop problems when the photos are too large and when the project your trying to burn is quite large as well. What is too large? I can only speak from own experience. I found that once a project gets into the range of 400 or more photos (total) my writer fails to write. (However, I've burned projects containing up to 388 successfully; photos at original size.) This can be solved by resizing your photos. I have a project with 466 photos (10 chapters) that wouldn't burn to disc. I then resized the photos so that every single one was under 500 KB. It worked: burning is now successful. Resizing doesn't necessarily mean that the quality of your photos will drop. I used Microsoft Office Picture Manager and, really, visually there is no difference between the original photos and the resized photos in the slideshow project. Experiment with photo size. Maybe another size works for you. It is also known that chosing the archive option (having the original photos and music burned to the disc) can upset the burning process - but only really when it's a very large project. Also, you could be using the wrong type of disc. I've been using DVD+R.
11407336
2/16/2020 6:37:48 AM • Individual... • Answered on Feb 16, 2020
2answers
Cannot get it onto DVD
Yes, use DVD+R. Make sure that you choose the correct options: After clicking on "Produce" and then "Burn to disc", take a look at the window that appears. One of the choices: you can either burn to hard drive or to the writer drive. Chose your writer drive and continue. Also, SlideShow Expressions can develop problems when a project is too big or when the photos are too large. What typically happens, is that the burning process stops at step 5 (the actual burning) and does'nt want to continue. If this is the case, experiment with photo size. I used Microsoft Office Picture Manager to resize photos. Resizing doesn't necessarily reduce the quality of the photos. There is really no visual difference between my original photos and those that feature in my slideshows. In my case I had to resize to under 500 KB, but then, my project was extremely large: 466 photos; maybe you don't have to go so low. Experiment with sizes. Don't give up; it's a really great product.
11407336
9/20/2019 6:34:29 AM • Individual... • Answered on Sep 20, 2019
2answers
How do you burn a dvd?
Two things: 1. Make sure that you chose the writer drive (burn to DVD) and not "hard drive" in the options window that appears when clicking on "Produce" and then on "Burn to disc". 2. SlideShow Expressions can have problems when the photos are too large and when the project your trying to burn is quite large as well. What is too large? I can only speak from own experience. I found that once a project gets into the range of 400 or more photos (total) my writer fails to write. (I've burned projects containing up to 388 successfully; photos at original size) However, this can be solved by resizing your photos. I have a project with 466 photos (10 chapters) that wouldn't burn to disc. I then resized the photos so that everyone were under 500 KB. It worked: burning is now successful. Resizing doesn't necessarily mean that the quality of your photos will drop. I used Microsoft Office Picture Manager and, really, visually there is no difference between the original photos and the resized photos in the slideshow project. Experiment with photo size. Maybe another size works for you. Also, you could be using the wrong type of disc. Try DVD+R.
7/18/2019 3:35:46 AM • Individual... • Answered on Jul 18, 2019
2answers
Had no problem with slide show. Purchased music
Best candeaeagle
Have you solved your problem yet?
I found the following information on Individual Software's website. Music files downloaded using iTunes are known to cause problems with SlideShow Expressions. Go to the following site for more reading; go to 'frequently asked questions': http://support.individualsoftware.com. I include some of the info underneath.
Why won't my music files work in Photo & Video Expressions? [SlideShow Ex. too, I guess]
Photo & Video Expressions is not compatible with audio files that have been protected by Digital Rights Management (DRM) functionality. Most audio files purchased online through Internet music retailers like iTunes, Urge, or Rhapsody are encrypted with some form of DRM. Similarly, audio files that have been extracted from a CD or DVD (the process known as "ripping") using certain media applications (iTunes, Windows Media Player, etc.) often have default settings that encrypt the files extracted.
There is no way to use DRM audio files purchased from online music retailers with Photo & Video Expressions. However, if you want to use music and audio files that you have extracted from your CD collection, then all you have to do is change the ripping setting in your media application before you extract the files to your computer.
To Change Your Ripping Settings:
iTunes
  1. Click Edit on the iTunes menu bar and click Preferences.
  2. Click the Advanced tab in the Preferences window.
  3. Click the Importing tab.
  4. Click the Import Using drop down arrow, and click MP3 Encoder.
  5. Click the Settings drop down arrow, and click the desired sound quality.
    (NOTE: The higher the kbps (kilobits per second), the larger the file.)
  6. The Custom... setting allows you to adjust more specific settings.
  7. Click the OK button when you are finished.
  8. Click the CD title in the left pane of the iTunes window.
  9. Click the checkbox for each track to rip, and then click the Import CD button in the lower right corner of the iTunes window.
  10. Once the extraction process has completed, you can use these audio files in your Photo & Video Expressions project.
3/29/2019 3:50:58 AM • Individual... • Answered on Mar 29, 2019
2answers
Why cant I add music.....all
Best george litt
I found the following information on Individual Software's website. Apparently, music downloaded from the Internet, or bought online, for example using iTunes, may cause problems with SlideShow Expressions. I include a link for more reading; go to 'frequently asked questions': http://support.individualsoftware.com.
Here is some of the info:
Why won't my music files work in Photo & Video Expressions? [SlideShow too, I guess]
Suggestions are given on how to change ripping settings in iTunes and Windows Media Player.
However, it is always good to contact the technical support team at individualsoftware.com. You first have to register your product with them in order to get help, but this online assistance is free and worthwhile trying out.
3/29/2019 3:35:21 AM • Individual... • Answered on Mar 29, 2019
I have SlideShow expression but too dumb to figure
You need to use the windows movie maker available in your computer and use your slideshow when making and add the music in it.
5/14/2018 12:54:02 AM • Individual... • Answered on May 14, 2018
Individual SlideShow Expressions Logo
Popular Tags
84 questions posted
Top Individual Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you an Individual Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Individual Computers & Internet
Most Popular Question
not save pictures
  • Computers & Internet
