20 Most Recent
Adobe InDesign CS3 Questions & Answers
Malayalam font problem in indesign
Shut down all programsand then find your font folder which is usually in C:windows\fonts or you can search your C: for the fonts folder. Once you find the fonts folder delete the malayalam font if it's in there.
Open internet explorer and go to: http://www.deepika.com/font.htm
- Click on "Download
font" below
- Save font in C:\ --> Windows --> Fonts
(some browsers may save the file name as a .exe extension.
Add .ttf to the end of the file name mlkr0ntt_TTF.
The file name should be mlkr0ntt_TTF.ttf
to work)
- Restart your computer
Now open your adobe program and see if you can use that font.
Hope this helps! If not contact me and I can find you another solution.
How to type telugu in indesign cs3
Are you using a Windows machine? If so, you'll probably need to make sure that you have a Telugu keyboard configuration in place:
- Open the Start Menu and click "Control Panel." Open
"Regional and Language Options" and then click "Change keyboards or
other input methods." Click the "Change keyboards" button.
- Click "Add" to add a new input language. Scroll down the
list until you find "Telugu." Click the "+" symbol to open up the
sub-menu. Open the keyboard sub-menu. Check the box for the keyboard
layout of your choice: Hindu Traditional or Telugu. Click "OK" when done
and click "OK" once more to close the language and region window.
In InDesign, you should be able to change the 'Language' of particular text from the Character palette. This option is at the bottom of the palette but I don't know if there is an option for Hindu or Telugu.
I am downloading software with problems
Are you using another browser other than IE? Some other browsers use the IE engine and will trigger this message. Also look at you running processes: Press Ctrl+Alt+Del (in Vista then select Task Manager) When task manager appears Click the Processes Tab, then click the word Description in the 5th coloum at the top of that coloum to sort on description. Scroll down to the "I" and see if you see "Internet Explorer" as a running process IF SO, and you know you have shut down Internet Explorer right click on IE and then select End Process and then answer yes.
When All instances of IE are remove from the processes then try to reinstall your software.
Let me know if this helped you!
I need tips on how to use it.
Hi. There are lots of online tutorials to get you going on Adobe InDesign and Photoshop CS3. Just google them and you'll find plenty of links.
Looking to create a banner
The quickest way (I find) is to
change your document size to the appropriate size you need, then just
select all and scale down (Object > Transform > Scale) until it's
close, then tweak to fit.
The standard way to set up large scale print is full-res at 25% scale.
So all images 300dpi at 25% of final output size - that will print
perfect. I would then normally send out as a PDF
Looking to create a banner.
Please follow the below link if you want to know how to create a banner -
http://onlinedefine.blogspot.com/2009/05/how-to-create-logon-banner-when-xp.html
or if you like to download a software to create banner please follow the below link -
http://www.download32.com/banner-software.html
Please post back some more comments is this helps or not.... if not please explain your problem in details...
Thanks
Adobe audition serial key please
am pascal Mbarubukeye as seen on my profile, i would like to ask for supporting me to offer serisl number of adobe audition 1.5, because what i have was corrupted. please help me i begg!
Serial code: 1325-1413-3017-0892-3878-8629
You should never post such codes on an open forum, others may use it against your wishes.
If you call Adobe, they will straighten out the issue for you if your codes are legitimately paid for.
