20 Most Recent Frigidaire FAD704DWD 70 Pint/Day Energy Star Dehumidifier w/ 16.3 Pint Tank Capacity, Up to 194 CFM, 115V, 2 Speeds, Antibacterial Mesh Filter, Auto Shut Off, Effortless Humidity Control, Full Tank Alert, Continuous Drain Option & Portable Design Questions & Answers
2answers
Is it possible to buy a portable dehumidifier which will automatically restart and function after a temporary power outage? What do you ask for?
Hello William, thank you for your post! I understand that you would like to have a dehumidifier that restarts after a power outage. I have reviewed the available models for Frigidaire and show that feature is not available. You may want to speak with additional manufacturers for that feature. I hope this information is helpful to you. -Matt
9/28/2017 2:25:53 PM • Frigidaire... • Answered on Sep 28, 2017
I am putting it on a platform so it will drain into my sink trap. how do i take off the casters so it will sit with stability?
Thank you for your post, Lee!
From the information you have provided you with like to take the caster wheels off in order to allow stability to your Frigidaire dehumidifier. We would not recommend removing the caster wheels. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
8/14/2015 2:59:39 PM • Frigidaire... • Answered on Aug 14, 2015
I have a FAD 704 DWD, does it not have a power on light? I called for a question regarding a different issue and the service tech said it was very bad to not have the on light "on".
Thank you for your inquiry, Lisa Cooper!
I understand that the power light on your Frigidaire dehumidifier is not showing you the power light is on. It sounds like you could have an issue with your control panel. If your dehumidifier is running it could be that the light has failed. If you have a current warranty I would reach out to your manufacturer to see if they have a resolution for such an issue. Hopefully this helps. -Matt
11/18/2014 3:10:36 PM • Frigidaire... • Answered on Nov 18, 2014
Frigidaire dehumidifier brand new will not start.
Hello Diane Weber, thank you for your inquiry! I see that you have recently purchased a Frigidaire dehumidifier and the display is not working properly. When you returned the original appliance did they test it in store to see if it worked? Are you using any type of extension cord or surge protector on the appliance? With this additional information I can better assist you. -Matt
9/2/2014 8:02:55 PM • Frigidaire... • Answered on Sep 02, 2014
Why does Frigidaire dehumidifier send water outside bucket?
Good Afternoon Jean, I understand that your Frigidaire dehumidifier, model# FAD704DWD, is putting the water that it collects out onto the floor as oppose to the bucket. I suggest contacting the manufacturer for more information. They should be able to point you in the right direction for assistance. Hope this is helpful. -Best Regards- WP
7/3/2014 11:17:14 PM • Frigidaire... • Answered on Jul 03, 2014
0answers
Meaning of "F1" in a Frigidaire Dehumidifier model FFAD5033R1?
For the slightly larger model, FFAD7033R1, F1 turned out to be the humidity sensor. This can be accessed by removing just the back panel.If you have a soldering iron for less than a nickel you can just replace the NTC Thermistor (small orange resistor 10k) on the small PCB. See attached image below.In the image below just to the right of the white sensor you can see I removed the bad thermistor..pxl_20220505_200138238-xcwecsr4zo4tymj3g1gtyjri-d-0.jpg
9/14/2022 11:35:48 AM • Frigidaire... • Answered on Sep 14, 2022
Why won't the tank of a Frigidaire FFAD2233W1 dehumidifier stay in place in the base unit?
Question edited for clarity. Question moved from Spanish car company Seat (See-At). Is it less than a year old? You can claim on the warranty. The water bucket seems to have to parts that might snag, the handle and the float arrangement. It just slides in on two tracks. If there is no water in in, tip it onto its back and see if it is mis-tracked. https://na2.electroluxmedia.com/XL/Electrolux/Electrolux%20Assets/images/Product%20Photography/FFAD2233W1-F6_944.jpg?impolicy=dimensions&imwidth=1400 https://www.frigidaire.ca/Home-Comfort/Dehumidifiers/FFAD2233W1/ Stuck Bucket. https://www.google.com/search?q=frigidaire+ffad2233w1+dehumidifier+bucket+stuck ..
4/5/2022 8:39:49 PM • Frigidaire... • Answered on Apr 05, 2022
Can the grill of a 70 pint Frigidaire be removed to clean the coil?
With your unit switched off, vacuum them with a brush attachment. If still dirty, you can spray with a degreasant spray and then gently rinse with a towel under the coils. Dry with a hair dryer. That is how refrigeration techs do it.
12/25/2021 10:33:55 PM • Frigidaire... • Answered on Dec 25, 2021
My Frigidaire dehumidifier compressor runs constantly and will not turn off with the switch. Have to unplug the unit.. Everything seems to be working to dehumidify. Is this a bad motherboard?
Does it run after you get to the optimal humidity level? If so, it's a bad humidity sensor switch A cheap fix is to put it on a timer. Otherwise replace the switch.
10/12/2021 5:14:13 PM • Frigidaire... • Answered on Oct 12, 2021
I have a FO code on my Frigidaire dehumidifier. Cleaning filter does not help. About four years old. Need to open case and check for rust?
First, I'm not a Frigidaire tech. * Check your warranty. Call for service. * Contact (note Live Chat link); https://www.frigidaire.com/Owner-Center/Contact-Us/ *** following is for information only *** * Be sure to check the tub and filter (make sure they are seated properly.) * Checking basic problems; https://www.youtube.com/watch?v=SXJrVGP_Ixs * Review; https://www.youtube.com/watch?v=BbwIEU3zlG8 * There are no customer service parts in unit other than what was mentioned in the video. * Contact Frigidaire or your local Appliance store for service. Aloha, ukeboy57
8/16/2021 9:50:26 PM • Frigidaire... • Answered on Aug 16, 2021
How to locate and replace internal filter?? For frigidaire
Good Afternoon Friend, I understand that you are trying to locate and replace the internal filter for your Frigidaire dehumidifier, model# LAD304NUL. I also see that you cannot find your manual. To locate and replace the filter, follow these easy steps. a. Remove the filter every two weeks based on normal operating conditions. b. To remove the filter, remove Bucket then pull filter downwards. c. Wash the filter with clean water then dry. d. Re-install the filter, and then replace Bucket. I have also included the link for your manual, where I found these instructions. Hope this is helpful. -Best Regards- WP Frigidaire Manual Search Results
7/7/2021 1:03:45 AM • Frigidaire... • Answered on Jul 07, 2021
Where can I buy a humidity sensor for my Frigidaire 70pt dehumidifier?
from or thru a dealer probably
6/5/2021 11:03:50 AM • Frigidaire... • Answered on Jun 05, 2021
Frigidaire FAD704DWD 70 Pint/Day Energy Star Dehumidifier w/ 16.3 Pint Tank Capacity, Up to 194 CFM, 115V, 2 Speeds, Antibacterial Mesh Filter, Auto Shut Off, Effortless Humidity Control, Full Tank Alert, Continuous Drain Option & Portable Design Logo
10 questions posted
Top Frigidaire Dehumidifiers Experts
john h
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Dehumidifiers
Most Popular Question
possible buy portable dehumidifier will
  • Dehumidifiers
