20 Most Recent
Mercury Regatta 8mph Road Mobility Scooter Questions & Answers
How much grease should I put in the electric motor?
First, make certain that you are using the recommended type of grease. Using a grease gun, slowly pump grease into the fitting until it begins to ooze out somewhere. Wipe off the (hopefully small amount of) grease that has oozed out, and you're done.
Where is the reset button on my scooter
hi, if memory serves me right it located under your feet ..
gently push it in...if you felt like you were pushing something back in , then it has popped otherwise no,.,..
Regards
Rob
How o get the wheel off
The center hub cover comes off with a small flat blade screw driver. It just pops off. Then take a wrench to remove the nut. Make sure you block up the frame so the wheel is not on the ground.
Dear FixYa,
When air is
There is no piston or plunger, as you would no it. It's the air pressure, when the bulb is squeezed that raises the mercury. When the valve on the bulb is released, it it releases the air pressure and the mercury falls.
What's really amazing is that you still have one of these old blood pressure monitors. They were outlawed in most countries 10 years ago, due to the high concentration of mercury in the tube. If for some reason the glass tube, that holds the mercury was broken or it leaked, you don't want to be standing around it. It's the same reason mercury filled thermometers are no longer manufactured or sold.
How do i adjust the
God day! I have checked with 4 major brands and the merc level is not adjustable. One company, Omron, told me that it is for safety and they did not want the merc played with..... Hope this helps, if so, please remember to vote.... Take care... Guy :)
A LEAK IN TOWER
Hello There,
Is it a leak in Mercury, you need to get a new one. If it is a leak in air being pumped, get the tubings change. If you suspect air leakage, you can use air bubbles in water to diagnose this.
Thanks & Cheers
How many protein bars should I eat per day?
Go with whole food proteins or quality whey shake. Make sure you know what you are eating, Cliff is probably one of the highest rated ones, so two bars would be fine along with normal meals. Whey protein is a naturally complete protein, meaning that it contains all of the essential amino acids required in the daily diet.
Whey protein is a rich source of branched chain amino acids (BCAAs), containing the highest known levels of any natural food source. BCAAs are important for athletes since unlike the other essential amino acids, they are metabolized directly into muscle tissue and are the first ones used during periods of exercise and resistance training.
Whey protein provides the body with BCAAs to replenish depleted levels and start repairing and rebuilding lean muscle tissue.
How often should I visit my dentist?
Most adult and children visit the dentist for regular
checkups and cleanings every six months. People at greater risk should have
checkups more often.
