Your computer is possibly infected by virus or malware.
Boot up into safemode with networking by pressing the F8 key as the computer boots up. Now if you can go online download and install advanced system care 8 which is free and do a full scan of your computer.Afterwards reboot your computer and see if it is running better.
In many cases FREE is not FREE: Your computer has an IP address that can be tracked by other when on line. You open up to invasions and spyware. Do not take the chance.
Open Device Manager, click the + to expand the various groups and find the driver you want to delete, right click on the item, and click "Uninstall." Note, however, that the next time you start Windows, it will see that there's new hardware with no driver and it will automatically try to find a driver for you. You might be able to cancel that process when it starts, but you might be better off to install the new driver you want to use before you restart your system.
LOL, why would you want to ? Vista is dead.... There's plenty of Online stores out there that you can get a legit copy of
Windows 7 for really cheap and Win 7 is waaaaaaaaaaaaaay better than Vista ever could be.
...and if your feeling lucky, there's lots of Torrent sites out there where you can get a "Pirated" copy for free...but beware of hidden virus' in those "Pirated" copies.
P.S. if your really set on a code to make Vista legit, I have several I'll give to you. heck I probably have 8 or 9 copies laying around...because I'm not gonna ever use them.
Please elaborate, a website is stuck n your pc screen? Or a program is non responsive. If the latter > hit ctrl+alt+delete, and select > start task manager then find the application, right click and select > go to process and then right click on that process and select > end process, this should terminate the browser along with the website
Crtl-Atl-Del and kill / end any unwanted processes.
Try
disabling startup programs. Go to Start > Run (search in Win 7) and type
MSConfig. In Startup tab, uncheck anything that you don't want Windows to
load automatically. It will make Windows boot faster and use less resources
while running. This just disables them in startup. Programs will still load,
but when only you initiate.
Open up Itunes in the top left hand corner select file from the drop down list select library then you will have options to back up to disc organise library export library import playlist and export playlist open Itunes in the top left hand corner select file from the drop down list you will see Library click to open then you should see back up to disk then more options back up entire library to diskother programs you might use to back up your Library http://download.cnet.com/sharepod/3000-2141_4-10794489.html Back up and restore your iPod or copy music and videos to and from the device. http://download.cnet.com/podtrans/3000-18546_4-75733600.html Transfer music to iPod or copy iPod music to your computer. Freeware Hope this helps.
That is your product ID. It is different from your MS Product Key, which is on your computer. It can also be traced with software like Belarc if the sticker is gone.
