20 Most Recent Microsoft Windows Vista Anytime Upgrade Questions & Answers
Window vista anytime upgrade
Windows anytime upgrade depend on your system locale as it is available in select countries only. For you I would suggest you to purchase an upgrade key from a local re-seller.
5/31/2012 10:15:59 AM • Microsoft... • Answered on May 31, 2012
Will musicmatch 7 be compatible with Vista
No, it is not compatible with the windows vista.
The new Yahoo version which does run on Vista cannot add
art work to MP3 tags
10/12/2010 5:02:51 PM • Microsoft... • Answered on Oct 12, 2010
Cant get scanjet 2100C to work with Windows Vista
Unfortunately, HP doesn't support Vista for that scanner model.
However, some have reported success using windows 2000 drivers on Vista.
You can give the windows 2000 drivers a try here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=59554&
Be sure to unplug the scanner from the computer BEFORE installing the driver / software.
6/8/2009 4:23:43 PM • Microsoft... • Answered on Jun 08, 2009
5answers
Microsoft office Bootstrapper has stopped
tep1: - Firewall Disable The users should try to temporarily disable Firewall or other security programs on their system. Step2: - Uninstall Old version of Microsoft Office If the users have installed the old version of Microsoft Office, then they need to instant uninstall it. In any case, if the MS office does not uninstall by using the Control Panel, then they have to download Microsoft Fix Tool and then use it to remove the old version of office of their PC. Step3: -Install Microsoft Office in Clean Boot Boot the system in the clean boot and then try to install the Office 2013 program and check that the clean boot is performed to disable all startup programs and the third party services on the machine. Also, check if they are conflicting with the Office installation. Then restart the computer in Windows Clean Boot and then try to install Microsoft Office 2013 program. Step4: - Check the Services Is Running Properly The users need to ensure that the following services are running properly in the services console. Go to "Start" button and then go to "Run" command. In the command prompt, type "Services.msc" cmd and tap on "Enter" key.
  • Check the Print Spooler
  • Check the Task Scheduler & respective dependencies
Step5:- Check Internet Connection The users need to ensure that their Internet Connection to the system is properly working or not. Might require download few Microsoft utilities at distinct stages. Step6:- Repair OSE Service Follow these steps:
  • Go to Office "install disc" option, and then find ose.exe and osetup.dll.
  • Then need to create a folder for OSE: C:\Program Files\Common Files\microsoft shared\Source Engine
  • Now copy the "OSE.exe" file to that folder.
  • Then restart your machine.
  • Now try to install Office again.
3/7/2024 12:32:09 PM • Microsoft... • Answered on Mar 07, 2024
Product key for ms office 2010 -X16-32007
Not all office disks have the same codes, no matter the version you may need a whole new installation disk with the corresponding code
2/15/2024 4:22:18 PM • Microsoft... • Answered on Feb 15, 2024
My microsoft intergrated webcam works good on skpe. It will not open for me to video myself offline. can I download the same type without messing up my computer
all you need is a camera program or app that is compatible with your operating system and the computer hardware also check to see that your drivers are up to date
2/15/2024 4:21:26 PM • Microsoft... • Answered on Feb 15, 2024
I WANT THE CONFIRMATION CODE FOR MICROSOFT OFFICE PROFESSIONAL 2007 7 CHARACTERS A,B,C,D,E,F,G
2/15/2024 4:15:17 PM • Microsoft... • Answered on Feb 15, 2024
3answers
Need information about robots as an introduction?
ROBOTS
One of the least discussed topics in hobby level robotics is software. You can almost always find a hardware description, schematic, drawing, and tons of help on the electro-mechanical side of your project. However, the software, which admittedly is one of the hard parts, eludes many people. In this article, I would like to demonstrate how to structure your software so your robot will function properly.
I would also like to point out a great technique for getting started. Many software engineers make heavy use of something called 'Pseudo Code'. This is a technique where you write your program in half programming language and half human language (English, Spanish, Driud, etc). Pseudo code is very useful for getting the layout of your program ready, to get basic algorithms worked out, and to be able to read your 'code' quickly. I will demonstrate this technique a little later.
As for programming languages, it doesn't matter which language you choose to use. I personally use the 'C' programming language the most. BASIC, Assembler, or FORTH are all fine choices. It turns out that the language is a small part of the structure of your program. The software has a job to do, and the key is to get it done! I am going to write this article in SBASIC, but the techniques are the same no matter which language you choose. SBASIC is available from Karl Lunts website at http://www.seanet.com/~karllunt/tips.htm.
GRAPHICS
Basic Graphic Design Principles Part 1 Lines and Shapes
by Kelly Paal
This is part one of a two part article.....click here to read part 2. As a graphic designer, you need to know the principles of graphic design in order to design at your best. Knowing what the design principles are will help you implement the best layouts and help you become aware of what you have done wrong in your past designs. This article details information regarding graphic design as it pertains to lines and shapes.
PC JOBS
Types of Computing Jobs
  • Data Entry - This is a job just about anyone can get. Basically, you take information from a piece of paper and use it to fill out a form on the computer. Many old hands who started out in this role are now heading up computer departments.
  • Secretarial/Administrative - This position involves some basic office skills. Not only must you understand the basics of using your computer and a few applications, but you'll probably also be expected to take dictation, answer phones, type letters, and keep things organized. In terms of computer skills, you should know how to use word processing, accounting, and spreadsheet programs at the very least. People in this role often move into other computing roles such as Managers, Meeting Organizers and Human Resources. Naturally you can move into mainstream computing areas, particularly QA and Testing.
  • Power User - Not so much a position as a status of being an extremely proficient user of (typically) Microsoft Office or similar tools. Advanced users of these tools become familiar with the basics of computer programming through starting with Excel macros or Access database programming. One can become very valuable to a small business by learning such skills, and even start to consult with other small businesses at rates typically starting around $50 an hour.
  • Customer Service/Telesales - These positions usually place a higher emphasis on phone skills than computer skills, but you should know at least the basics of how to use your computer.
  • Technical Support (Production Support) - Most companies consider technical support to be an entry-level computer job. You are expected to know the operating systems on which the product you'll support will run, and you'll also need to know the basics of any programs that product might interact with. The good news is that the company will teach you what you need to know about their products - you just need to learn everything else. Success in technical support requires good problem-solving skills and a great deal of attention to detail. Technical Support and Problem Management is a rapidly growing area. Users now rely heavily on Help Lines, International Support Centers and the like.
  • Software Quality Assurance (SQA) Engineer - You need to know as much as the best technical support personnel. You need to be a problem solver, a detective, and sometimes even a Customer Service representative. You'll also need some basic programming skills, since more and more companies are beginning to rely on automated testing. The best SQA engineers understand a little (or a lot) about every aspect of computers, from building them to using them to programming them.
  • Software Engineer (Developer or Programmer) - To get a job at a top software shop such as Microsoft or Google, you'll need a degree in computer science and detailed understanding of the field. However getting a developer position in some small company may be easier. What do you need to know is the language in which you'll be programming. It is also important to know database fundamentals and (if programming for Windows) the Windows API. Knowing more than one programming language is very helpful. Understanding many of the basic fundamentals of computer science (e.g. linked lists, arrays, pointers, object oriented programming) will be essential in demonstrating your proficiency.
  • Business Analyst (Analyst or Systems Analyst or Analyst/Programmer or User Analyst) - This is a relatively new title, but the role is as "old as the hills". People can become a BA with any mix of business and computing skills. It is really a matter of looking at what the company is really after. A good BA should know the process from end to end. The BA is primarily the connection between the business and the developers. To get into this job, and into computing, good knowledge of a business is helpful. So, if you gain good knowledge through your job, and maybe do a computer course, you can get your foot in the door.
1/23/2024 8:20:10 AM • Microsoft... • Answered on Jan 23, 2024
2answers
Please i want source code calculator using asp.net
i want the source code for simple calculater in asp.net
1/8/2024 10:28:36 AM • Microsoft... • Answered on Jan 08, 2024
Is Microsoft Office Online similar to Google Docs?
NO, They are diffrent
12/26/2023 7:28:23 AM • Microsoft... • Answered on Dec 26, 2023
3answers
What is product key? nd
Please sent me for spb mobile shell softwares resistration keys
11/5/2023 6:35:23 AM • Microsoft... • Answered on Nov 05, 2023
2answers
Signature keyboard stopped working on Microsoft Surface pro x
simplest way to troubleshoot is to try another keyboard to determine whether your ports are in good order. Alternatively, try the signature keyboard on another device to determine if its working
8/31/2023 3:34:34 AM • Microsoft... • Answered on Aug 31, 2023
Lost a Word font on my Mac and I can't get it back.
If you have already tried the common troubleshooting steps with no success, here are a few additional suggestions:
  1. Clear font caches: Font caches can sometimes cause issues with font recognition. To clear them, follow these steps:
  • Close all applications, including Word.
  • In Finder, press Command+Shift+G, then enter "~/Library/Caches" and click Go.
  • Locate the "com.apple.ATS" folder and move it to the trash.
  • Restart your Mac and check if the font now appears in Word.
  1. Check if the font is disabled in Font Book: Sometimes, a font may be disabled in Font Book, which can cause it to not appear in certain applications. To check and enable the font if needed:
  • Open Font Book (you can search for it using Spotlight).
  • Locate the font in question and ensure it is enabled (unchecked fonts won't appear in applications).
  • If it is disabled, check the box next to it to enable it.
  1. Repair disk permissions: Although less likely to resolve font issues, repairing disk permissions might help in some cases. Here's how to do it:
  • Open Disk Utility (you can search for it using Spotlight).
  • Select your main disk (usually named Macintosh HD) from the list on the left.
  • Click on the First Aid tab, then click the "Repair Disk Permissions" button.
  • Wait for the process to complete, then restart your Mac and check if the font is now visible in Word.
  1. Create a new user account: In some instances, font-related problems can be specific to a user account. Creating a new user account and testing the font in Word under that account can help identify whether the issue is related to your current account.
If none of the above solutions work, you might need to seek further assistance from Microsoft support or Apple support, as the problem could be related to a software conflict or compatibility issue.
8/1/2023 4:58:04 PM • Microsoft... • Answered on Aug 01, 2023
2answers
Need a Microsoft office 2007 word free download for windows 10
Try downloading it from this Microsoft website. I've seen some claims that this version will install with W10. You will of course need your ***********. Download Earlier Versions of Office In looking around I've seen lots of people having this problem since an update of W10 in late 2015. I'm staying on W7 because of older games and the fact that Microsoft can follow every last little thing you do on W10. Please let us know if this solves your problem, so other's will know about it.
7/23/2023 8:20:43 AM • Microsoft... • Answered on Jul 23, 2023
3answers
Would like to have a powerpoint background for
Background are not possible to print.. dont know why...
But you can do one thing take a print out of the backgroung image from paint and then print your philosophy of art lesson using ppt....
6/25/2023 8:50:19 PM • Microsoft... • Answered on Jun 25, 2023
2answers
I want to download microsoft office 365
go to a local computer/ office supplies sales shop and buy the disc
6/21/2023 8:09:51 AM • Microsoft... • Answered on Jun 21, 2023
2answers
Where is the pairing button on Microsoft wireless keyboard 6000 v3.0 or does it need a USB plug
The Microsoft Wireless Keyboard 6000 v3.0 comes with a USB transceiver that you need to plug into your computer's USB port to connect the keyboard to your computer. The keyboard and the transceiver are pre-paired from the factory, so you don't need to pair them again unless you replace the transceiver or the keyboard. If you do need to pair the keyboard and the transceiver again, you can follow these steps: 1. Insert the USB transceiver into your computer's USB port. 2. Turn on the keyboard. 3. Press and hold the "Connect" button on the underside of the keyboard for a few seconds until the green light on the transceiver starts flashing. 4. Press the "Connect" button on the USB transceiver. 5. The green light on the transceiver should stop flashing and stay on, indicating that the keyboard and the transceiver are now paired. Note that there is no separate pairing button on the Microsoft Wireless Keyboard 6000 v3.0 itself. hope it would be of use to you
6/19/2023 11:26:19 PM • Microsoft... • Answered on Jun 19, 2023
Full download for windows 8 Microsoft
6/12/2023 10:50:02 AM • Microsoft... • Answered on Jun 12, 2023
I was using it on microsoft 8 with an Photoshop 13. Upgraded Microsoft 10 and the 4850 does not work. The message I get is no WIA device is located is there something I can do to get it working?
If you upgraded your operating system from Windows 8 to Windows 10 and are experiencing issues with your HP 4850 scanner, specifically receiving a "no WIA device is located" message, here are a few steps you can try to resolve the problem: 1. Check Scanner Compatibility: Ensure that the HP 4850 scanner is compatible with Windows 10. Visit the official HP website and search for the scanner model to find compatibility information and any available drivers or software updates specifically designed for Windows 10. 2. Update Drivers: Download and install the latest drivers for the HP 4850 scanner compatible with Windows 10 from the HP website. Make sure to select the correct drivers for your specific scanner model and the version of Windows 10 you are using. 3. Uninstall and Reinstall Software: Completely uninstall the existing HP scanning software from your computer. Go to the Control Panel, locate the scanner software, and uninstall it. Afterward, restart your computer and reinstall the latest version of the software provided by HP for Windows 10. 4. Run Hardware Troubleshooter: Windows 10 has a built-in hardware troubleshooter that can automatically detect and fix common issues. Open the Windows Settings, go to "Update & Security," select "Troubleshoot," and then choose "Hardware and Devices." Follow the on-screen instructions to run the troubleshooter and see if it resolves the problem. 5. Check WIA Service: Verify that the Windows Image Acquisition (WIA) service is running on your computer. Press Win + R on your keyboard, type "services.msc," and press Enter. In the Services window, locate the "Windows Image Acquisition (WIA)" service, right-click on it, select "Properties," set the startup type to "Automatic," and click "Start" to initiate the service if it's not already running. 6. Try Compatibility Mode: Right-click on the scanner software executable file or shortcut, select "Properties," go to the "Compatibility" tab, and check the option to run the program in compatibility mode. Choose the previous Windows version (Windows 8) and apply the settings. Then, try running the software again and check if the scanner is recognized. If none of these steps resolve the issue, it's recommended to contact HP's customer support or visit their website for further assistance. They will have specific knowledge and resources to address any compatibility or functionality problems with your HP 4850 scanner on Windows 10.
5/24/2023 2:57:44 AM • Microsoft... • Answered on May 24, 2023
Problem with an app called YTD Downloader?
Question edited for clarity and all the typos. Just for Info, we are Fixya dot com, we are not Microsoft and we aren't YTD Downloader. Microsoft only sell their own Apps, I think you bought this app via an online advert WITHIN their website. It is called click through advertising. Microsoft has allowed an Add On to the Microsoft Edge Browser as mentioned down below. If you have problems with the Pro Version, reach out to YTD Downloader Support. Check you Spam / Junk Folder for the confirmation email
Download YouTube Videos ' MP4 converter
YTD Video Downloader https://www.ytddownloader.com > download-youtube... YTD is a software tool that allows you to download entire YouTube playlists and ... Free Version Browser Add-on.
YouTube Downloader - Microsoft Edge Addons
Microsoft https://microsoftedge.microsoft.com > addons > detail The YouTube Downloader is an extension that provides downloading videos from YouTube. Open YouTube with a video you want to download.
5/17/2023 1:02:24 AM • Microsoft... • Answered on May 17, 2023
Microsoft Windows Vista Anytime Upgrade Logo
5 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Computers & Internet
Most Popular Question
window vista anytime upgrade
  • Computers & Internet
