20 Most Recent
Sony VAIO CS VGNCS215JP Questions & Answers
Win xp is not installed on sony vgn-cs17g laptop
probably the cd may be corrupted or first u format the previous installed advanced os using that os installation disc and then install xp.because if u r using windows vista or seven it won roll back to previous versions.
Another option is you can have two os on two drives
Regards,
sathyamoorthy
I format my sony vaio
If you have formatted the hard drive, you are quite correct, you will have no system recovery data.
The cheapest place to purchase a new system will be ebay but beware of bogus disks!
My screen has red dots
when the red dots show up is because the front cover of the screen is a bit loose fron the auctual screen it self!
All you can do locally is take screen off the laptop as try to press the screen from the side corners that maybe works for a litle while then you'll need to get a new one!
My Sony Vaio CS Series laptop keeps freezing
look`s like you have a virus problem try reinstalling your operating sistem much better than restoring with microsoft app because all viruses go there so use recovery cd to fix that
I want to know the name of multimedia oanel driver
Here is the link from where you can download the drivers plus know the manufacturer name of the chipset.
http://www.sony.co.in/support/download/365365/product/vgn-cs17g/sectionfirst?subpage=detail
if you want original drivers, below is the link
http://www.sony.co.in/support/download/288974/product/vgn-cs17g
Sony Vaio CS17G Volume Control Problem
you need to install your sound driver and camera driver again. but in compatible mode. this time you open the control panel and look for the option under programs and features titled"run program made for older version of windows" and install the two drivers.they will start working
Camera driver
Here is the link from where you can download the camera driver for your Notebook.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCS215JP&LOC=3
Just paste the URL in your web browser and Select the Operating System for which you want the Camera driver and Click Camera and download the driver.
That's it
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
