20 Most Recent HP G70-250us Notebook Questions & Answers
2answers
Laptop keys to the keyboard
The keys are the little square things in a grid below the screen.
4/28/2022 4:47:59 PM • HP G70-250us... • Answered on Apr 28, 2022
Hinge stiff on hp model g70
it's broken and like most things broken (even Telescope Hubble) it needs to be repair using new parts. or sent to a shop. called PC repair shop. parts are not easy to find but seen on ebay if you look used. most G70s are dead now so lots of spare old parts sold for it. even cheap , LCD panel hinges. etc.
4/14/2022 12:23:39 PM • HP G70-250us... • Answered on Apr 14, 2022
2answers
Keyboard freeze after a while, need to power down and back up again
check with external usb keyboard - if that dont solve the issue reset or restore with fresh copy of windows. if all above don't work - make bios to reset in worst nothing works than its hardware issue
12/19/2017 1:39:48 PM • HP G70-250us... • Answered on Dec 19, 2017
I have an HP G70
does it run on battery alone does it run on ac power pack alone both work , one does , ? try a new battery, no battery ever lasted this long so ill bet battery is END OF LIFE. there are 100 G70s models. which one is yours.? service tag info? my guess the battery is 8 years old or more. and toast.
4/1/2017 6:41:40 PM • HP G70-250us... • Answered on Apr 01, 2017
I have a HP Pavilion G70-250US Notebook that
no operating system even stated. Xp/vista/w7/w9/w10/ linux ,what.... must we guess? is your internet connection working? it must or PNP will be near brain DEAD ,do that first. ok guess w10. why not see if OTHER USB works first barrow a real mouse not that battery dead wireless wonder mouse? get a real mouse make sure that works then put in a new battery in your wireless mouse RTM it tells you how USB tests, all so obvious. use real desktop key board , that work or USB memory stick , add file to it, see other files you have there>? only clues here is USB dead, 2 months old.(means new? or new to you?) next, in w10 go to CP then go to device manager be ONLINE see yell or red error there that driver stack? bingo bad driver reload any that are bad. end story google how to reload a windows 10 driver, be like 10,000,0000 hits.
3/16/2017 9:19:27 PM • HP G70-250us... • Answered on Mar 16, 2017
Why does my hp g 70 have sound light but no picture?
try hooking an external monitor up to it, if you get display, then it's probably your Lcd display having problems and needs to be replaced, sometimes it could be the power inverter or back light in the display.
8/29/2014 2:13:47 PM • HP G70-250us... • Answered on Aug 29, 2014
Wireless button fn
Hold down Fn+F2 key.
6/30/2013 3:13:21 AM • HP G70-250us... • Answered on Jun 30, 2013
Hp g70 lid actuator
you pulled your lcd cable and sounds like its arching on a conection remove lcd inspect cable reinsulate with a tape electrical should be fine but suggest checking conection on both lcd and board its a easy fix
2/28/2013 2:17:37 PM • HP G70-250us... • Answered on Feb 28, 2013
Screen frame broke
Screen frame being the Display Bezel.http://h10032.www1.hp.com/ctg/Manual/c01573159.pdfWith the laptop closed, the top cover is the Display Enclosure.Is it broken also?http://www.lapzone.com/servlet/the-54572/HP-Pavilion-G70-17-dsh-inch/DetailCan you say OUCH! That's the cheapest I found, but it was a quick search. Hopefully you'll have better luck in searching.The HP part number, for the Display Bezel of the HP G70 series, is;HP 488386-001The HP part number for the Display Enclosure is;HP 488379-001http://www.lapzone.com/servlet/the-54572/HP-Pavilion-G70-17-dsh-inch/DetailBase Enclosure;With built-in modem, Digital Media slot, AND -> with HDMI port,HP 489114-001,http://www.impactcomputers.com/489114-001.htmlBase Enclosure:WITH built-in modem, Digital Media slot, and NO -> HDMI port,HP 501252-001,http://www.ebay.com/itm/ORIGINAL-COMPAQ-CQ70-Case-Bottom-Covers-501252-001-Grade-A-/330628933816?pt=LH_DefaultDomain_0&hash=item4cfb0528b8Hinge Kit; (2 each Hinges),HP 488384-001,http://battery-adapter.com/product_info.php/products_id/3900/vSPS:+488384-001You have more damage than just the Display Bezel, I feel.Access what damage you have, and I'll step by step guide you in replacing.Just post back in a Comment.Regards,joecoolvette
1/30/2013 1:05:00 AM • HP G70-250us... • Answered on Jan 30, 2013
Usb port dont work
First check in device manager about USB controller status if its not yellow mark then or not present check in the bios about hardware is disabled or not present at last if anything not works you have to replace your usb controller if its onboard then get additional from market and fix in the PCI socket
12/7/2011 1:11:05 PM • HP G70-250us... • Answered on Dec 07, 2011
Hp g70 - 212e only displaying hp logo and not booting
You need to check hard disk in bios its detecting or not also check boot options
12/7/2011 1:05:50 PM • HP G70-250us... • Answered on Dec 07, 2011
My HP G70-258US (Vista OS) hard drive will only
i would advise a different os than vista but you can put the old hard drive back in run it in safe mode and by a cheap external hard drive case and transfer the files for the operating system to the new hard drive and then switch the drives back out
10/7/2011 3:06:46 PM • HP G70-250us... • Answered on Oct 07, 2011
I had to have my
I would go to the hp site (www.hp.com) and go to the support option.
They give you a place to put your computer model and then click on downloads.
You should be able to download the software that you lost.
7/28/2011 11:55:45 PM • HP G70-250us... • Answered on Jul 28, 2011
2answers
Hi i want to install
http://driverpacks.net/driverpacks/latest go here scroll to bottom and download the "mass storage" driver pack. This will have the SATA driver for your HP. Now if you want to know how to do it right watch this guy. Its flawless and Ive used his video 4 my own HP laptop. http://www.youtube.com/watch?v=v1K5zds_AaM
6/27/2011 2:52:31 AM • HP G70-250us... • Answered on Jun 27, 2011
Built in mic by web
i think your mic is working properly. so you can download the camera software (amcap is better) from anywhere.
if you need more help just use the link http://amcap.en.softonic.com/download
3/28/2011 11:52:46 AM • HP G70-250us... • Answered on Mar 28, 2011
I have a HP G7-250CA
Hi
can you please explain to us how the hard drive crashed during a bios update ?
or how do you know that the hard drive crashed during bios update
many thanks
And did you try to reinstall windows while original hard drive was still in the laptop
did you press the F11 key as soon as you pressed the power on key
3/7/2011 3:14:15 PM • HP G70-250us... • Answered on Mar 07, 2011
My webcam isnt working
If this is what is within the laptop then if is possible that
1. the web-cam is defective- failure of the hardware
2. The drivers of the web cam is faulty and so you need to reinstall them if a restoration will not reset.
3. the Operating software is faulty
4. Fault in the mother board,failure of the link to the web cam mounted on the lid.
1/25/2011 5:52:00 AM • HP G70-250us... • Answered on Jan 25, 2011
How do i turn on
Webcam can be accessed only through certain programs that support it. The most popular ones are VoIP and IM apps. You can view the webcam using a software called Cyberlink YouCam. Download Now!
12/6/2010 11:48:55 AM • HP G70-250us... • Answered on Dec 06, 2010
Memory upgrade for hp g71-34ous
You will have to go to an accessories store and ask for a DIMM Memory and add it in. Its added at the bottom when you remove the laptop cover and looks like below.
12/5/2010 5:51:26 AM • HP G70-250us... • Answered on Dec 05, 2010
HP G70-250us Notebook Logo
70 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
hp g70 258us vista os hard drive will
  • Computers & Internet
