20 Most Recent
Muratec M1250 Fax Questions & Answers
NOT ABLE TO SEND FAX WITH ADSL LINE
Can you pick up the handset and dial a number and speak to the other person using the handset..?? You might just require a filter which your telephone company should be able to provide.
Error message - "check Rec. Paper"
Check rec. paper means that the paper may not be routed properly thro' the cutter mechanism and out thro' the machine....if it is; then the sensors that detect the paper may be dirty or faulty.
Muratec m 1250
Probably just needs cleaning. Try using rubbing alcohol to clean the head.
Fax Numbers-Memory?
Unfortunately that is a function of the sending unit. If they did not program their number in, then you won't have a record. If this is a persistent problem, you may want to sign up for Caller ID.
Even if they put the paper in upside down, your fax will still print a head on top of the page with the information they have programmed. If they program a wrong fax number, then all you will have is a wrong number.
Wish I have better new for you.
Ed
Muratec MFX-2725 says there's a paper jam in C1 but I can't find anything
from the picture of the printer, I'm seeing that there are 4 trays to check. Please double check that you've checked all 4 trays and also the back of the printer.
You can also check that you're not using the incorrect type of paper for your printer. If you're using a new type of paper, then this might be the issue. And then you can check the back of your printer as well. Thank you.
