20 Most Recent
Advent Netbook Questions & Answers
Hi , hope you can
Here is what was found on the Microsoft page as a fix for your issue
Error xc0000034
http://windowsfixup.com/2009/06/windows-vista-sp2-wont-boot-error-0xc0000034-fix/
I cant activ webcam on
You can use the key combination to on or off your webcam.
Fn + F6 - Turn Webcam on/off.
Thanks for using FixYa.
How do I connect my
down ;load the wan driver and then put the wifi code into the system when ask for
Where do I find on the motherboard, the battery for the Advent netbook
Since you did not include the model number of the netbook, I will give you a couple of generic locations where you may find the CMOS battery.
It could be tucked away under the keyboard encased in yellow plastic; or on some models, you would find it by removing the battery pack; remove the large cover over the cooling fan; in the upper left corner is a white oblong cover with two screws- remove that piece and the CMOS battery should be held in place with tape.
Where is wireless switch on advent 4211 B
Go to the Control Panel, click on "Device Manager", click on "Network Adapters" and select the wireless adapter you use. Right-click on it and select "Enable". That should turn it on.
How To Replace Memory
Hello there should be a small hath with 1-2 screws on it remove those screws an you will have access to the memory compartment then u can remove the memory there and replace with a higher GB one.
Good luck
Advent 4213 0xc000000f Error
Download this tool and make a USB Windows 7 Installation drive.http://www.microsoftstore.com/store/msstore/html/pbPage.Help_Win7_usbdvd_dwnToolA free legal Windows image can be downloaded. Check the MS Product Key sticker for what version your system came with. You may have to use your key. IT MUST BE THE SAME VERSION.Windows 7 Home Premium SP1http://www.mydigitallife.info/official-windows-7-sp1-iso-from-digital-river/Windows 7 Home Premium http://msft-dnl.digitalrivercontent.net/msvista/pub/X15-65733/X15-65733.isoDownload correct version and burn onto DVD to use. In your case, you need a Virtual CD-ROM player like Magic ISO to make USB installer.
Not quick or even fast, but true.
Advent problems
the cable between keyboard and computer is lose or fitted in place.
