20 Most Recent Toshiba Satellite A135-S4727 Notebook Questions & Answers
2answers
Why wont dvd's play
1. your device is not a 'DVD-ROM' device, nor a 'CD-RW/DVD-ROM' combo device.
2. you need software, such as the free 'VLD' software, to decode the DVD, and to "play" the video.
3. your DVD-disk is scratched -- will it play in some other computer or stand-alone DVD-player?
1/9/2020 2:20:37 AM • Toshiba... • Answered on Jan 09, 2020
Why is my Toshiba Satellite L505D-GS6000 Wifi driver not found?? After resetting, checking device manager, trying fn+f8, and dowloading the driver it still doesn't show up!!!
Sounds like a bad wireless card or the card slot.I would try replacing the wireless card.When wireless cards go bad they either cause the laptop to not boot,low or no signal reception or the card isn't seen at all by the motherboard or operating system or .both.If it isn't showing in device manager either with a caution sign or installed the card is most likely bad
3/9/2012 2:02:41 PM • Toshiba... • Answered on Mar 09, 2012
Laptop screen black but flickers on FN-F5
It sounds like your either backlight is goin out in the lcd screen,,,or possibbility its your lcd inverter,,,like you said hook to external screen,,if it comes on its one of the two,,,one way to see if its backlight or not is to ,,turn it on,,shaine a flashlight at lcd,,if u see ur normal screen,,,its back light ,,,if not its inverter goin out,,good luck,,if back light,,u will need new lcd screen,,,easier if its the inverter,,,u just take off lcd bezel,,down at the bottom of lcd panel,,2 screws,,and can find easy on ,,internet and ebay,,
12/26/2011 7:24:52 AM • Toshiba... • Answered on Dec 26, 2011
Bootmgr is missing toshiba
If bootmgr is missing..your computer wont turn on....you have to now reinstall the operating system.
you can try with the inbuilt system recovery..or you can use a os cd to do that.
8/20/2011 2:47:11 AM • Toshiba... • Answered on Aug 20, 2011
Model is Satellite A135-S4727. Boots
when it goes to the black screen give it a few seconds after the mouse shows up. Ctrl+Alt+Del and select task manager, then select the process tab. click on explorer, then right click on it and select end process from the pop up menu. once it has disappeared go back to the first tab programs. click new task, type explorer and hit enter. see where it gets you from there. if that doesnt help please recover your computer per manufacture instructions.
3/20/2011 4:14:44 PM • Toshiba... • Answered on Mar 20, 2011
My laptop was working but the screen was black.
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
3/10/2011 8:33:33 AM • Toshiba... • Answered on Mar 10, 2011
I have registry errors that
reboot as safe mode and then clean as possible the registry
2/8/2011 4:31:26 PM • Toshiba... • Answered on Feb 08, 2011
My toshiba get really hot
If the internal fan is working, you should sense air moving in or out of vents. If it isn't working, the unit will soon die if the fan is not replaced.
You may need a cooling pad under the unit such as are shown here:
Cooling pads
If they are powered by the laptop itself (via USB for example), they will shorten the run-time of the battery.
2/4/2011 1:10:08 AM • Toshiba... • Answered on Feb 04, 2011
Fan is very noisy and I cannot find a new one to
Browse ebay with the fan part number. Should be one out there or contact toshiba.com for a service centre in your area.
1/5/2011 3:31:08 PM • Toshiba... • Answered on Jan 05, 2011
Problem with laptop turning on, the power light
a red light normaly idicates the wrong power i would recomend a new charger.
10/6/2010 1:29:53 AM • Toshiba... • Answered on Oct 06, 2010
My laptop monitor gets distorted
First must make sure that the problem in the screen and not in the card Alclcp by connecting the device to screen Hargip if the image is good to be change the screen
4/17/2010 6:10:44 PM • Toshiba... • Answered on Apr 17, 2010
I'm unable to access the internet. Missing
Hi, (" Cut & Paste") this Website to the "search", and should be able to get the Drivers that you need. (www.driversoftwaredownload.com/tag/driver-toshiba)
"Did this help"
2/3/2010 7:02:55 PM • Toshiba... • Answered on Feb 03, 2010
I think my mobob is
yes the mother board is bad! it most likely over heated and took it out. you have done everything you can do to test it unless you know how to test electronics and have the equipment to do so!
9/28/2009 3:48:35 AM • Toshiba... • Answered on Sep 28, 2009
3answers
Is the product key for Microsoft office 2013 the same as all product keys for 2013 Microsoft offices that operate under laptops using windows 8.1?
The product key is associated with the MS Office 2013 software, not the specific MS Windows version of Operating System - unless the MS Office lists a minimum version of OS ie: "Windows 8.0" In this case, it would not install on Windows 7. Otherwise, you should be able to install it on Windows 7, Windows 8, or later.
2/15/2024 4:30:57 PM • Toshiba... • Answered on Feb 15, 2024
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM • Toshiba... • Answered on May 22, 2023
HOW TO ENABLE TOUCHPAD ON TOSHIBA SATELLITE a665-S6080
In BIOS, I made Pointing Device Enable and It has been done.
11/28/2022 9:05:08 AM • Toshiba... • Answered on Nov 28, 2022
2answers
Hello I have a Toshiba E45 B4200 and the OS is lock with a password and I don't know the password I can't use it and I don't know what to do please help me my phone number is +509(REMOVED) I have What
Question edited to remove phone number. Never do that!! We have 12 million views here a year or which 5% are scammers. Question moved from Toshiba Televisions to computers. Take it to a computer shop and they will take it apart and fix the motherboard to remove the BIOS Password.
3/22/2022 12:20:21 PM • Toshiba... • Answered on Mar 22, 2022
2answers
No picture on videos on my laptop
They are created with different encoding and Windows Media PLayer doesn't decode all so-called CODECs by default. Go to videolan.org and download the VLC media player. It can play about any video you can throw at it. VideoLAN VLC Official site Free multimedia solutions for all OS
2/13/2022 1:00:17 PM • Toshiba... • Answered on Feb 13, 2022
Toshiba Satellite A135-S4727 Notebook Logo
16 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
laptop screen black but flickers fn f5
  • Computers & Internet
