20 Most Recent Casio EXILIM EX-FC100 Digital Camera Questions & Answers
2answers
I haven't touch the memory
Take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos. This blog article reviews and outlines several of the better ones.
Now AFTER you've recovered your photos, you'll need to format your card IN YOUR CAMERA using your camera's built-in format feature. This will rejuvenate the card, and will prevent this from happening again (bet you never formatted the card when you first got it?). Formatting the card when first used is necessary to preserve the card's file structure. It may work fine at first if not formatted, but in nearly all cases it will corrupt with time if it wasn't formatted. Note that formatting will also erase the card, so again format only after you've recovered and saved your photos onto your computer.
12/5/2013 1:22:18 AM • Casio EXILIM... • Answered on Dec 05, 2013
Unfortunately pictures deleted form camera how can we get them back
Recuva (pronounced "recover") is a freeware Windows utility to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from digital camera memory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses!
  • Put the memory card into an USB card reader and plug it into the USB port in your computer, then run the Recuva program.
  • Simple to use interface - just click 'Scan' and choose the files you want to recover
  • Easy to use filter for results based on file name/type
  • Simple Windows like interface with List and Tree view
  • Can be run from a USB thumb drive
  • Restores all types of files, office documents, images, video, music, email, anything.
  • Supports FAT12, FAT16, FAT32, exFAT, NTFS, NTFS5 , NTFS + EFS file systems
  • Restores files from removable media (SmartMedia, Secure Digital, MemoryStick, Digital cameras, Floppy disks, Jazz Disks, Sony Memory Sticks, Compact Flash cards, Smart Media Cards, Secure Digital Cards, etc.)
  • Restores files from external ZIP drives, Firewire and USB Hard drives
  • It's fast, tiny and takes seconds to run!
Go to these WEB sites to down Recuva http://download.cnet.com/Recuva/3000-2242_4-10753287.html www.filehippo.com/download_recuva
3/3/2013 7:22:29 AM • Casio EXILIM... • Answered on Mar 03, 2013
My lens i not moving it displays
1/29/2013 6:25:55 PM • Casio EXILIM... • Answered on Jan 29, 2013
Memory card does not get in
make sure you're putting it in the right way round. if you're trying the right way then it will slip in easily, if it's the wrong way it will just jam and the lid won't close
7/24/2012 6:12:46 PM • Casio EXILIM... • Answered on Jul 24, 2012
2answers
My new camera start only in play mode
Warranty needs to be extra sized
9/29/2011 5:51:07 AM • Casio EXILIM... • Answered on Sep 29, 2011
I have a casio exilim
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
11/29/2010 7:59:03 AM • Casio EXILIM... • Answered on Nov 29, 2010
ONDE ENCONTRO O MANUA, ON-LINE, DESSA CAMARA ?
Hello
Download HERE.
Kind regards
Andrea
8/27/2010 10:14:48 AM • Casio EXILIM... • Answered on Aug 27, 2010
Running vista, can't upload pics from casio
Use a card reader instead of the camera.
5/11/2010 1:10:04 PM • Casio EXILIM... • Answered on May 11, 2010
When switching the power on, the green light goes
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
1/17/2010 12:11:16 AM • Casio EXILIM... • Answered on Jan 17, 2010
Need instructions manual to casio Exilim digital camera Ex S8 12.1 pixels
Look it up on Google
9/16/2019 6:06:50 PM • Casio Exilim... • Answered on Sep 16, 2019
How do I identify my casio camera`s model by using the serial number?
The quickest way is to put the serial number into your search engine. To double check yourself, look thru the images until you see a picture of the camera you own.
8/16/2016 9:03:54 PM • Casio Exilim... • Answered on Aug 16, 2016
Instructions on operation
Digital Cameras - Manuals - CASIO
support.casio.com > Support > Manuals
CasioIn order to use this service to download user's guides and operating instructions (manuals), you must agree to be bound by the following "Terms and Conditions.
Manuals - Support - CASIO
User Manual for Casio Watch Module - My G-Shock
12/28/2015 1:03:33 AM • Casio Exilim... • Answered on Dec 28, 2015
0perating instruction
[PDF]Operation Guide 5410 - Support - Casio
support.casio.com/en/manual/009/qw5410.pdf
CasioThis User's Guide uses numbers shown above to identify watch hands and ..... follow the instructions in this manual, especially the information under "Operating ...
12/28/2015 1:02:43 AM • Casio Exilim... • Answered on Dec 28, 2015
I am asking anyone who has firmware for casio ex z40, to help me clear the system error. please send it to me to my email address([email protected])
Sorry, we don't send e-mails. Only when you have the right tools and software to flash a camera from Casio, you could use firmware. You can't put in there firmware, when the camera is not 100% functional. Once the flashing of the new firmware starts, it can't be stopped, because it is writing new software that has no connection with the older software. And a part of the old with a part of the new software does not make one correct program. So NEVER try to solve a system error with a update. The system error must be repaired by a pro.
3/5/2015 9:57:59 PM • Casio Exilim... • Answered on Mar 05, 2015
How do i unlock the card on my exilim.casio camera
Remove the card and see if the pictures remain on the camera. If they do, then they are stored in camera memory. Make sure the memory lock on the card is in the proper position. Put the card back into your computer and delete the pictures. Then format the card, and try the card again. If the card is still locked, try a different memory card that has been formatted.
2/27/2015 1:24:51 PM • Casio Exilim... • Answered on Feb 27, 2015
I need to replace the battery cover for my Casio EX-Z60
Good luck with this. Casio doesn't sell parts. Try Ebay.
12/6/2014 5:01:05 AM • Casio Exilim... • Answered on Dec 06, 2014
Casio EXILIM EX-FC100 Digital Camera Logo
23 questions posted
Top Casio Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Casio Camera Expert? Answer questions, earn points and help others
View Most Popular
Exilim Casio
  • Exilim Casio
Most Popular Question
memory card not get in
  • Cameras
