20 Most Recent
LG L196WTQ-BF 19" Monitor Questions & Answers
19" LCD not powering on
EL7 is not a coil. it is a connection point to the transformer, check the transformer for short circuit. Also check the bridge rectifier that is in that path.
Monitor will not awake from
That means your monitor is not receiving a signal from your video card.
A couple things to check:
*Make sure your cable is ok - unplug and replug the cable to see if it is a loose connection. Or try a different cable.
*Make sure your computer is not in sleep mode - Move your mouse or otherwise ensure your computer is awake and sending a video signal
*If you have another computer, try the monitor on the other system and see if it works.
So I've got an LG L196WTQ that I've taken
Hello Whiteknight
Even a single capacitor failing can cause the monitor to not power up right. Some of the capacitors in the power supply actually are used to start the oscillators that drive the board if they fail the board never starts up. The remaining capacitors are filter caps that help provide steady output voltages, if they fail then the voltages fluctuate and the power good signal does not go on or it goes on and off which make the power button flash. If you can solder then you can repair the monitor yourself for less than $15 in parts. We have a step by step repair guide posted on our site at:
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/ This is a very common problem with LCD monitors when they get a few years old.
I hope this helps, if so please rate my solution.
BuddyMc
My LG L196wtq-BF went black this morning. No
We have some dis-assembly guides on our web site at: www.ccl-la.com/badcaps.htm There are not for your exact model but they should help.
Buddy
Corporate Computer
www.ccl-la.com
Dead Screen
Hey hows it going,
My name is ArmyMason, lets see if I can get you going in the right direction. www.partstore.com might have a deal on the parts you need but I am thinking it would be cheaper for you to buy a new monitor or consider hitting up a local pawn shop for a cheap replacement. These parts can cost more than the whole monitor because LG buys parts in major quanity and we all know (WalMart effect) the more you buy the cheaper the price. So if you need to take it apart in the back of the monitor are a bunch of screws start unscrewing and make sure you know where they all go. tape them near the hole so that you can find them later. Once all apart, be sure to wear gloves, dont want anything to possiably contaminate you. (LEAD)... get the part number off the screen and look it up in that site. Order it and replace it. It is straight forward to replacing it.
Good Luck,
ArmyMason
What normally burns out the LG Hi-Fi Amplifier?
Full 'make model (what it is)' in all questions please, first 3 words.
Capacitors can split or bulge, resistors can burn,, the transformer can fail internally..
Take it for repair unless you have the thousands of dollars of test equipment and have do the 2 year electronic course.
What does 9 red flashes mean on LG multi V LMU540HV
A communication error has occurred between the outdoor and indoor units. Faulty wiring or a malfunctioning control unit may be responsible. Contact LG customer service for assistance. Their number is 1 800 243 0000.
