20 Most Recent
Pitney Bowes C180 Copier Questions & Answers
Error: E7 -01
the sorter bins are binding when they try to move. check for alignment
Pitney Bowes DI425 deflector error.
Error 26 is referred the explorer can be in favor heavy of dirt, which causes that it does not have the suitable speed of return. Clean and you lubricate the zones of work of the to explorer.
Modle c4000 code c 0070
check that the toner bottle is in coreectly. remove the toner bottle and close the door. wait for the motor to stop turning (3 minutes) insert toner bottle with hole facing up.
Pitney Bowes Model 9016 Error code E3 01
E3-01 is the toner bottle rotation. for some reason it is not rotating. Take out the toner bottle and be sure it is in coreectly, that the labels are not loose and preventing it from turning.
Pitney Bowes C420
The drum or the cleaning unit has gotten too worn. call 18002435556
C180 copier error code E7
The e7 code is for the sorter problem. you can either call for service 18002435556 or just remove the sorter and use the copier without it.
FAULT CODE P0500
Fuser error code. unbend a paper clip and push in hole on right side of control panel. watch the control panel on the left side about 2/3 up a dot will appear. when it shows up, press 3. press trouble reset. Touch exit.
turn machine on and off. If it comes back up, reset again. 3rd time it needs a new fusing unit. Call 18002435556 for service.
