20 Most Recent
Lexmark E360d Laser Printer Questions & Answers
Pc life warning on Lexmark
PC life warning indicates that the photoconductor has nearly reached its expected life rating. You can still continue printing but will be at risk for developing print quality issues. It is advisable that pc unit be replaced. Now, when you replace the pc unit you will also need to manually reset the pc page counter as well. Thank you for choosing Lexmark.
Print is blurry
Remove the toner cartridge and print cartridge
assembly. Slightly shake it from side to side to redistribute toner properly. Also, please check the supply level of your toner cartridge.You might want to consider replacing the toner cartridge since you have already replace the PC unit.Also, check the transfer roll for signs of toner buildup and contamination.Inspect the HVPS contact (transfer roll) for contamination. Verify the high voltage cable is plugged into the LVPS/HVPS.If all the steps mentioned above were done. I would suggest you contact Lexmark Technical Support for further assistance.
Need to reset the pc
Please click on the link below to see instructions on how to go about the procedure.
http://bit.ly/oSJU64
For further assistance, please contact Lexmark Technical Support.
Reset the pc page counter
Please click on the linkbelow to see instructions on how to go about the procedure.
For further assistance,please contact Lexmark Technical Support.
