20 Most Recent
ViewSonic N3752w 37 in. LCD TV Questions & Answers
What is the code to use on a universal remote
Each brand of universal remote could have it's own code for the TV so without more info, no one can help you.You can also check to see if you have a search feature on the remote which will allow you to try every code until one works.
Analog
You will have to use the HDMI input to go digital. Without looking at the set I don't know what type of hookups you have in the back but there should be numerous ways to hook up to the digital link. You may also need an adapter depending on what kind of hook - up you have. Let me know if you have any other problems.Gillight
My viewsonic tv power light turns on, but the screen is blank. how can i fix this?
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves
checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
