20 Most Recent
Toshiba REGZA 32XV515DG 32 in. LCD HDTV Questions & Answers
32'' Toshiba Regza difficuut to switch on from plug & standby
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "
brand name" to your device; [Exclude the model number], in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mother bord
To buy a genuine one, contact the authorized service center for Toshiba.
Is it ok to turn a Toshiba LCD TV off at the power
Yes its fine to turn the power off at the power point. In fact this saves money because there is no idle appliance power drain. It is also a safe practice to disconnect the power at night or over longer periods of inactivity because there have been instances where plasmas in particular have caught on fire. Turning the power off will not affect your friends LCD TV they are designed and built by engineers who incorporate power surge protection. The circuit breaker should be one of very good quality and if this is the case then your friends LCD will be fine.
HI
I have a 32xv515dg LCD-TV.
It
This is a common problem an a failry easy DIY fix.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
- No video, Power light is on or blinking.
- TV is making a clicking noise.
- TV takes a while to come on
- Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
How do you safely clean the lcd tv screen52 inch
A: "We recommend using LCD cleanser that can be purchased at any electronics store," says a customer service tech for Westinghouse, a manufacturer of popular LCD televisions. The cleaner can be found in both spray and wipe form. But what exactly goes into these LCD solutions?
Kai Hui of MG Chemicals, makers of one of many available LCD cleaners, explains, "The main ingredient in most wipes on the market is water. There needs to be a small percentage of isopropyl alcohol (IPA) to help get rid of the grease from busy fingers." Some LCD cleaning solutions may include up to 50 percent IPA, according to Hui, but any more than that could damage the screens.
Since I'd never suggest you spend more money than you have to, I'd start with a clean, soft cloth and regular ol' tap water. You can add just a capful of isopropyl alcohol to a glass of water if you need something to help loosen the greasy gunk on the screen, so it can wipe off more easily. Get the cloth damp and then apply to the screen instead of splashing the screen and trying to wipe up the liquid; and always -- always -- use a clean cloth, as tiny, hard particles trapped in the fibers can scratch the surface of your screen
I AM LOOKING FOR A TV TUNER OF MY REGZA MODEL NO.
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers for spare part supplies as required.
Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge.
I hope this helps.
TV Won't turn on
hi
go to this site download ur tv manual and see what may be the problem hope it helps it might be kids lock or something to that effect then buttons on tv wont work until reset http://www.nodevice.com/
