20 Most Recent
Sansui HDLCD1908 19 in. LCD TV Questions & Answers
No picture no power kids pushed it off the dresser
Ouch. If you are lucky unplug double check cord connection at back. No help? Wire at plug end may have torn in the fall. Wiggle wire at the plug end if you get something the cord needs to be replaced. Otherwise, you may have major damage. A lightly used replacement may be less than a repair.
SERVICE CODE
If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Tv wont power up
Ensure the power outlet is ok and if on doubt, check the TV on some other. If it does not work, the TV has some blown fuses or other board/component failures.
Computer vga cable/ sansui tv problem
HelloNvedia signals cannot be porcessed by Sansui Tv. You have tow options before you to connect your self assembled computer to this tV. The first one is try by reducing the resolution f VGA output. for that, go to Nvidea control [normally will be displayed at the right end of the taskbar] and chage relolution there. By default, the resolution will be 1024/768. Select it to the lowest; 800/600. If the TV display it, just advance it to the next highest; 960/600.If this does not help you, there is no other way than change the computer's video card to any other, which works on Windows Video Drive. Can be bought from local computer component market, insert it to one amoung the free PCI socket of the computer and do the next proceedings to change over video output from on board video out, and feed this video signal to yur TV. OK.
Got new cable service and
The simplest thing to do is contact your cable service. This mishap can be reset by them if you give them the information that they ask, they should be able to remove the block or even give you the password. All and all...call them!Hope this helps ^_^
We are trying to hook
if you want audio as well, it will depend on what kind of audio connection your tv has next to the VGA (computer monitor) connection. If it looks like the normal RCA audio, (red and white plugs) you will need to get a male headphone jack (to plug into your computer headphone or speaker out jack) to stereo RCA cable so you would have a headphone jack on one side of the cable and a red and white plug on the other side. Now if your TV just has what look like a headphone jack next to the VGA (computer monitor plug) you will need to buy a male to male stereo headphone jack cable. for both of these, just make sure the cable you get it long enough, or buy an extension.
I have a Sansui HDLCD 19WB. Can I add speakers?
Yes, you can either plug speakers into the back of the monitor in the orange colored slot. But in order for this to work, you must also plug the computer tower audio output into the Sansui's audio input port, which is located directly underneath the monitor's video input (where it is already connected to the computer). If that sounds like too much work, you could always just plug your computer speakers directly into the audio out of your computer tower.
I relocated to another state
It will connect in the back of the TV. You will see a female socket under the lip of the RCA connections and RF connectors. This power cord is just like the computer power cord you already use! Thanks for asking and show a few hands of support!
