20 Most Recent Samsung LA22A450 22 in. LCD TV Questions & Answers
Samsung LCD TV No picture only sound, Samsung logo appears when switch on
PARTS. BN41-00988A MODAL LA22A450C1
3/11/2015 7:14:48 AM • Samsung LA22A450... • Answered on Mar 11, 2015
Have reset samsong la22a450 and still no channel
SAMSUNG LCD 22IN MODEL LA22 A45OC1LXL MOTHERBORD MY PH9030932645 CALLME
1/31/2015 6:00:06 PM • Samsung LA22A450... • Answered on Jan 31, 2015
My tv always standby no tv on
Hi, The power supply board in your tv needs to be repaired or replaced.
10/12/2014 4:32:40 PM • Samsung LA22A450... • Answered on Oct 12, 2014
My tv takes time to turn on
There are a few ways to cure this problem:
  1. Do not turn off your TV
  2. Allow time for your TV to turn on before your programme starts.
  3. Ask someone else to turn the TV on five minutes before you come home and only turn it off when you're going out.
10/6/2014 6:52:51 PM • Samsung LA22A450... • Answered on Oct 06, 2014
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
10/6/2014 2:12:13 PM • Samsung LA22A450... • Answered on Oct 06, 2014
How to turn off music when turning on tv
Yes it is possible. You should be able to set the melody to off, low, medium or high I believe you can get to the setting by doing this:
  • Press the MENU button to display the on-screen menu.
  • Press the up or down button to select "Setup", then press the ENTER button.
  • Select "Melody" by pressing the up or down button, then press the ENTER button.
  • Select the setting you want (Off) by pressing the up or down button repeatedly.
  • Press the ENTER button.
  • Press the EXIT button to exit.
You can find the manual here: http://downloadcenter.samsung.com/content/UM/200804/20080401185600828_BN68-01507A-01Eng-0328.pdf Page 24/25 is where it talks about the Melody setting.
9/10/2014 12:45:59 PM • Samsung LA22A450... • Answered on Sep 10, 2014
0answers
Samsung lcdtvla22a450c1 only stand by mode no display
This is a common problem with this model Replace the main board.
1/8/2014 8:34:24 AM • Samsung LA22A450... • Answered on Jan 08, 2014
White screen
Shorted chorma processor IC at main board. Contact any service technician.
1/5/2014 3:22:09 PM • Samsung LA22A450... • Answered on Jan 05, 2014
Required Remote
If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
3/22/2013 2:20:47 AM • Samsung LA22A450... • Answered on Mar 22, 2013
Samsung LA22A450 22 in. LCD TV Logo
48 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LA Samsung
  • LA Samsung
Most Popular Question
white screen
  • Televison & Video
