20 Most Recent Panasonic TH-C42HD18 42 in. Plasma TV Questions & Answers
42" Panasonic plasma tv has scrolling lines
SMOOTHING CAP OR TRANSFORMER SND BK TO THEM
9/28/2017 1:31:20 PM • Panasonic... • Answered on Sep 28, 2017
TV turned on with the
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
6/25/2017 1:35:30 PM • Panasonic... • Answered on Jun 25, 2017
HDMI remains black and no sound
change the source select on tv to hdmi
11/17/2013 1:10:47 PM • Panasonic... • Answered on Nov 17, 2013
I have a Panasonic TH-C42HD18 Plasma, it has been
Sustain board fault suspected. If you wish to get more details, check this link. It has screen-shots to defective Plasma Displays. You can compare them to that of your TVs, and make sure about the fault. It will be best. http://electronicshelponline.blogspot.com/ Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
9/21/2013 3:19:51 PM • Panasonic... • Answered on Sep 21, 2013
Red light now blinking two times after i left it
This is not a power supply issue. It sounds that an inverter board fault. If you wish to get more details about the blinking codes to panasonic TVs, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
9/14/2013 3:37:07 PM • Panasonic... • Answered on Sep 14, 2013
Blinking times
Four times blinks denotes a failure to back light inverter. If you wish to get more details about the blinking codes to Plasma TVs, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
9/14/2013 2:52:03 PM • Panasonic... • Answered on Sep 14, 2013
0answers
Blinking 4 times
Be the first to answer 9/14/2013 2:31:46 PM • Panasonic... • Posted on Sep 14, 2013Be the first to answer
Can your power cord be bad on a panasonic plasma tv to cause it to turn off and not start again and blow a fuse on pb
The main power regulator board will have some shorted component/s on it. Normally, these boards to plasma TVs are irreparable. Card base replacement should be done.
1/29/2013 8:12:00 AM • Panasonic... • Answered on Jan 29, 2013
Panasonic TH-C42HD18 42 In. Plasma TV inputs not working
yes. you find the main board for you panasonic plasma tv from shopjimmy.com.. good luck!
9/6/2012 8:43:13 PM • Panasonic... • Answered on Sep 06, 2012
TH-C4HD18
the four holes on rear are for wall mounted bracket, the stand that goes in bottom generally requires the removing of a cover plate which will be about size of the upper part of stand and will be approx four screws, remove cover and stand will slot in and fix with scres/bolts accordingly.
5/6/2012 4:46:47 PM • Panasonic... • Answered on May 06, 2012
My panasonci-c42hd18 wont turn on-no
have the fuses checked on the power supply board.
11/30/2011 5:22:39 PM • Panasonic... • Answered on Nov 30, 2011
2answers
I have a panasonic TH-C42HD18.
If you have no power light on TV ,then you must have a blowed Fuse on the power supply board.
Check Fuse and check board for Bad Capacitors they will be vented or swollen on Top.
1000uf 16v 2200uf 10v 3300uf 10v.
6/2/2011 1:14:35 PM • Panasonic... • Answered on Jun 02, 2011
Th-c42fd18 blinking two times, no
I can't find any info on this model number, are you sure you got it right?
2 flashes is usually related to the power board. It may be caused by a bad ventilation. Probably the fans are very dirty and can't refrigerate the set.
After replacing the power board, clean the fans.
I hope this helps.
4/8/2011 11:51:50 AM • Panasonic... • Answered on Apr 08, 2011
I need the transistor RJK5020
Go to newark electronics on line.
10/23/2010 12:14:05 AM • Panasonic... • Answered on Oct 23, 2010
Panasonic TH-C42HD18 Blinking Power LED (7 times)
NEED SD OR SU OR SC BOARD REPLACED
9/21/2009 7:22:34 AM • Panasonic... • Answered on Sep 21, 2009
We have a Pensonic led 3216 led cut, when we try to open it the screen is all black how to fix it? how to do a reset n the tv
Not totally sure what your asking but I think your saying your LED lamps aren't working, if that's the case replace them
10/15/2021 10:33:14 PM • Panasonic TH... • Answered on Oct 15, 2021
Panasonic TH-C42HD18 42 in. Plasma TV Logo
30 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
TH Panasonic
  • TH Panasonic
Most Popular Question
red light now blinking two times after
  • Televison & Video
