20 Most Recent
Envision Monitors L26W761 26 in. LCD HDTV Questions & Answers
My tv has no sound,
Try unplugging the power cord from the TV for 10 seconds then plugging it back in. This may reset the TV and resolve the issue.
-G33k
9/20/2011 12:37:52 AM •
Envision...
Answered
on Sep 20, 2011
Screen got very brite very quick. Now I have no
I have not repaired this model of TV. I would certainly say, that the inverter is bad. The inverters are a sort of ballast that produces high voltages to light your TV screen. Bad capacitors and in some cases resistors change values and will create problems as you describe. I would recommend you replace the inverter board. Thanks for asking and show all hands of support!
4/15/2011 4:37:31 AM •
Envision...
Answered
on Apr 15, 2011
No sound at all
Assuming
you are using the standard Wifi cable which has a red, white and yellow
connector, you should connect them to the yellow, red and white
connectors on the back. They should be together. The red, green and
blue that are bundled together are component inputs for hd.
11/13/2010 5:23:44 AM •
Envision...
Answered
on Nov 13, 2010
Envision L26W761 remote stopped woking
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
10/7/2010 10:01:22 PM •
Envision...
Answered
on Oct 07, 2010
No sound from the Wii.
Assuming you are using the standard Wii cable which has a red, white and yellow connector, you should connect them to the yellow, red and white connectors on the back. They should be together. The red, green and blue that are bundled togehter are component inputs for hd.
12/22/2009 3:02:15 PM •
Envision...
Answered
on Dec 22, 2009
Parental control
try autoprogam in the channels first.then see if they will change.if not you will need to replace
the main digital board.you can purchase the
board from shopjimmy.com
7/29/2009 1:26:15 AM •
Envision...
Answered
on Jul 29, 2009
