20 Most Recent
Symphonic SC720FDF 20 inch TV/VCR/DVD Combo TV Questions & Answers
Can not get the tv
my tv keeps turning off when i turn it on does these tvs have a timer in them that rsults in this happening?
11/15/2011 6:24:37 PM •
Symphonic...
Answered
on Nov 15, 2011
When I turn on my symphonic tv I just get snow and no sound
If you are seeing snow on your Symphonic TV screen, it could indicate that the TV is not receiving a signal from your cable or antenna. Here are some steps you can take to troubleshoot the issue:
- Check the cable or antenna connection: Ensure that the coaxial cable or antenna is securely connected to the TV and the wall or source.
- Run a channel scan: Perform a channel scan or auto-programming to ensure that the TV is tuned to the correct channels and that it is receiving a signal.
- Check the TV's settings: Make sure that the TV's input is set to the correct source, such as cable or antenna. Also, ensure that the TV's settings are not set to "mute" or "no sound."
- Try a different device: If you have another device, such as a DVD player or gaming console, try connecting it to the TV to see if it is able to display video and sound.
If none of these steps work, you may need to contact a professional technician or the manufacturer for further assistance.
2/28/2023 1:49:24 PM •
Symphonic...
Answered
on Feb 28, 2023
Code list for symphonic tv
Symphonic TV 3 Digit Remote Control Codes
198
003
053
155
189
Symphonic TV 4 Digit Remote Control Codes
1280
1384
1483
1484
1024
1031
1036
1105
6/13/2018 8:14:44 PM •
Symphonic...
Answered
on Jun 13, 2018
My symphonic tv shuts off
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
2/20/2018 4:08:43 AM •
Symphonic...
Answered
on Feb 20, 2018
