20 Most Recent Motorola CLS 1110 (1 Channel) 2-Way Radio Questions & Answers
2answers
I have two motorola cls 1110 walkie talkies that
In testing we have been unable to duplcate your flash r13 F8. You might try restoring the factory settings by holding the PTT and the MENU button in for 3 seconds while turning the radio ON. (You will need to do this to all your CLS1110 radios in order for them all to match.) If this doesn't clear the problem, then try swapping the battery with a known good radio and see if it solves the issue. If so, you need a new rechargeable battery pack. If resetting the radio and / or changing the battery does not solve the problem then your radio likely needs replaced. Schematics and parts were never made available for this model. Best regards.
3/15/2017 1:16:45 PM • Motorola CLS... • Answered on Mar 15, 2017
Dock red light
Flashing Red Light is not charging and solid red light mean charging the radio battery.
7/11/2016 5:24:31 AM • Motorola CLS... • Answered on Jul 11, 2016
2answers
2answers
Changed the battery in my 2-Way Radio CLS1110 and it will turn on but when you push talk it goes off
The battery is bad or not charged. Check your charger and charger/battery connection. Clean all contacts with a pencil eraser and try charging again. With a new battery it may take up to 3 charge cycles to fully charge your battery. Best regards.
2/17/2016 11:40:40 PM • Motorola CLS... • Answered on Feb 17, 2016
How to change frequency on motorola cls 1110
Here's a link to the user guide https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwiC0sze6uLJAhVGZCYKHZXPAzsQFggzMAE&url=http%3A%2F%2Fsupport.radioshack.com%2Fsupport_electronics%2Fdoc71%2F71607.pdf&usg=AFQjCNH713XET4rJahFjWGFIU0-PFW21vA&cad=rja
12/17/2015 12:17:07 PM • Motorola CLS... • Answered on Dec 17, 2015
2answers
My Motorola CLS1110 Two way
You may have a bad battery, or even dirty battery contacts. A few troubleshooting ideas include:
1) Swap the battery to another known good CLS1110 radio and see if the other radio has the same problem when placed on the charger. If so, you have a bad battery. This type of battery typically lasts approx. 18-24 months before needing replaced.
2) If swapping the battery proves to be successful, check the battery contacts on the affected radio for debris, scum or dirt. Clean the contacts on the charger and the radio with a pencil eraser if needed. (The fact you have to readjust the walkie in the charger indicates you might have problems with the contacts.)
3) Try the battery from the known good radio in the affected radio, if the battery charges correctly, you know the radio is fine. If the charger blinks with the known good battery, then you know you have a radio problem.
Best regards.
8/26/2015 6:19:52 PM • Motorola CLS... • Answered on Aug 26, 2015
How do i replace the antenna to a cls1110?
Replacing the antenna is rather easy and will take only a few minutes. Please see a short YouTube video on how to do it. Parts are available on ShopWiscomm.com Amazon or Ebay https://www.youtube.com/watch?v=JbQn-6-xgPk Motorola CLS1110 CLS1410 Replacement Antenna Installation Instructions
3/31/2015 12:38:12 PM • Motorola CLS... • Answered on Mar 31, 2015
Motorola Solutions CLS1110:i'm trying to fix the
We work on these all the time. At the top, pry off the plastic clip where the carry clip clicks in. Under this, there are two more torx screws. Now it comes apart! The antenna is soldered onto the main board and not really replaceable. We re-solder them fairly often. We replace them by using broken radios. Motorola does not sell this part. Email if you want parts. We have a lot of CLS.
3/15/2015 2:45:24 AM • Motorola CLS... • Answered on Mar 15, 2015
2answers
Is motorola cls-1110 compatible with bpr40 radios
yes, with conditions. The CLS comes preprogrammed with frequencies and tone codes. The BPR requires software and cables. It is not a preprogrammed business radio, but a fully programmable business radio. If your BPR radios are first: UHF, then they can be programmed to match the CLS. Do note, a few of the CLS frequencies are approved by the FCC for low power only, meaning a maximum of 2 watt power output. Find a dealer willing to do the programming for you if you do not understand. Our shop does it often.
3/15/2015 2:34:58 AM • Motorola CLS... • Answered on Mar 15, 2015
HOW TO SNYC MOTOROLA CLS1110 TO MJ270R
Sorry, these two radio have no common frequencies.
1/8/2015 4:47:42 PM • Motorola CLS... • Answered on Jan 08, 2015
Cls1110 hold mon
Here's a link to the user guide http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0CDQQFjAB&url=http%3A%2F%2Fwww.axcesstechnologysource.com%2Fmanuals%2Fcls_series_userguide.pdf&ei=1K6uVN3bIYikNsykg6AK&usg=AFQjCNHicPhdIfAnW0RvYf03G6KeqBqkBA&sig2=prqdNr24Qi09zfv9PolaTg&bvm=bv.83134100,d.eXY
1/8/2015 4:23:19 PM • Motorola CLS... • Answered on Jan 08, 2015
How do I change the channel on all my Motorola CLS1110?
Here is a link to the user guide http://www.weatherconnection.com/manuals/CLS1110.pdf See page 28 for programming instructions. Best regards.
1/6/2015 5:52:42 PM • Motorola CLS... • Answered on Jan 06, 2015
3answers
My motorola cls 1110 turns on, but no communication can be heard
internal regulation has failed the RX and TX circuits share a common control circuit the PLL and its micro so perhaps this parts 5volt supply has failed some radios has a small two pin fuse that looks like a 3 pin black small to92 transistor perhaps the batterys cells are bad check the packs output is ok
12/17/2014 5:57:47 AM • Motorola CLS... • Answered on Dec 17, 2014
Why does Motorola CLS 6 bank charger blinking red lights when no radios on charger?
It is best to contact Motorola Solutions. Http://www.motorolasolutions.com/support Mark Motorola Mobility Supp
8/18/2014 10:50:15 PM • Motorola CLS... • Answered on Aug 18, 2014
Why static on motorola CLS 1110?
Are you referring to static (random snapping, crackling, popping) that only occurs when you are handling the radio, or a steady hissing sound when turned on? The first may indicate the radio has a defect or loose internal connection; the second is reduced by adjusting the squelch setting. More information is always helpful.
8/2/2014 4:57:09 PM • Motorola CLS... • Answered on Aug 02, 2014
Cls 1110 work with clp1060
7/14/2014 9:18:17 PM • Motorola CLS... • Answered on Jul 14, 2014
How can you test a band radio earpiece cord
An earpiece cord often breaks internally. The test is to put it on a known working radio and see if it works. If so, then you test the audio jack on the radio, which is better left up to a service shop. I assume you are using a cord with the correct Motorola pins and not trying to "make" something work. The make idea is great, but often ends in disaster.
6/4/2014 7:11:13 PM • Motorola CLS... • Answered on Jun 04, 2014
How do you test cp200 cords for shortage
With a volt-ohm meter.
3/25/2014 2:59:31 PM • Motorola CLS... • Answered on Mar 25, 2014
What device do you use to test a cp200 earpiece cord
The best test is a radio with a known good or new accessory jack. Cords to earpieces and other audio accessories are the common failure part of the device. They can be damaged at the grommet (near the plugs) by users who repeatedly plug and unplug them. The wiggling side-to-side motion can break solders and wire connections. Also some users will twirl the earpiece on the wire when not in use, a bad nervous habit which can break the wire in the cord. Earpiece are not considered repairable, and simply need replaced when they fail. The other thing you could be having trouble with is the audio accessory jack on the radio. This can be damaged by repeated use, and can get wobbled out over time. Each seems to have their own "sweet spot", sometimes simply swapping earpieces with another radio will make a previously failed device work great. On the CP200 radio it is strongly advised to use the optional audio accessory retain to hold any plug in place. Then you can leave your device plugged in and save wear-n-tear on the jack. Best regards
2/25/2014 9:26:31 PM • Motorola CLS... • Answered on Feb 25, 2014
Motorola CLS 1110 (1 Channel) 2-Way Radio Logo
81 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
get motorola cls 1110 work baofeng uv5r
  • Radio Communications
