20 Most Recent
HP G60-230US Notebook Questions & Answers
My HP G60-230US Computer will not start.
The
sounds like your motherboard malfunctioned. the board was probably starting to go out. thats why it would see the hdd then not.
you sound like youre familiar with computers. you may want to invest in diagnostic cards to troubleshoot problems like this. theyre fairly inexpensive on ebay. basically you insert the card into pci slot and it displays an error code. then you look up the code in a book. works like the obd2 reader for your car.
good luck
My wireless light on my
I had that same problem, I turns out about a day later I dropped the laptop on accident and it started working again. I would not advise my way of getting the button to work again.
Walk thru settings for wireless service
here is drivers and manual for your laptop - http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&tmp_geoLoc=true&product=3860153to acsses wireless network settings in windows 7 go to start - control panel - network centre
Hp g60 laptop internal battery replacement is this
Simple. Unplug the machine, and remove the HDD cover. The battery with the two wires on is a standard watch battery. Simply remove the tape over the battery, and replace with the same type of battery. Job done.
Wobbling screen, shaking screen
You need to get to the plug on the motherboard that goes to the screen and take it off and put it back on again...it is loose. If you don't know how to take it apart to do so, get a friend that does that kind of thing and have them do it. hope this helps!
