20 Most Recent Gateway HD2201 22" LCD Monitor Questions & Answers
2answers
When attached via HDMI, monitor goes to
First shut down the pc and then plug in new monitor then boot up and see if windows 7 will auto find the monitor.
is this a single display or are you using 2 monitors, i had 2 monitors and used the other to change the display on mine when i had this problem i am also using windows 7 and reboot usually fixes display problems because it wont see old monitor any more and detect the new one.
also update any video drivers you have like nvidia or ati(catalyst controll center)
12/5/2015 8:22:38 AM • Gateway HD2201... • Answered on Dec 05, 2015
The monitor won't come on it shows RGB no signal
Are you using the correct cord (HDMI, VGA, etc.)?
9/20/2014 8:28:21 PM • Gateway HD2201... • Answered on Sep 20, 2014
0answers
0answers
0answers
Need the operation manuel for my 22inch Gateway monitor can't change operating language
I have a smaller sized Gateway monitor than yours, but I'm sure the monitor buttons (on the front) perform the same functions on all sizes.You should have eight control buttons on the front of the bezel (as listed from left to right): source, menu, down arrow, up arrow, left arrow, right arrow, auto/set, and on/off buttons.Press the menu button, the first dialog screen that appears (at least on mine) is the brightness/contrast function. The screen will show the function to be changed, and a very small picture of what screen you have in view.Once the first function is listed on the screen, press the down arrow to access the other screens (color, tracking and set-up), each having their own little picture indicating what screen you are looking at.Brightness/contrast - picture of half light, half dark circlecolor - RGB picturetracking - two squares on top on one another slightly off centerset-up- hand pointing leftYou want the set-up screen which shows a picture (I think) of a little hand pointing to the left. Once you are in the set-up screen, press the auto/set button and the first line will be highlighted (usually it is the language choice).Once highlighted, press the right arrow button until your language name appears (i.e., English, Duetsch, Francais, Espanol Italiano, -there is no choice on mine for Japanese, etc.).Press the menu button again and that should do it.
2/11/2013 9:24:32 PM • Gateway HD2201... • Answered on Feb 11, 2013
0answers
Trying to get my gateway
Rotation is depended on the graphic card installed. There should be an additional item in the control panel of the computer for you graphic interface. Select it and rotation should be available there, if it's an option of the graphics card.
9/2/2011 7:47:11 PM • Gateway HD2201... • Answered on Sep 02, 2011
I have a gateway desktop
So you can see at least two bad caps, then you need to replace them, there should be a set of caps for the 5v power supply for the logic circuits and the set of caps for the16~18 vdc power supply for the backlights inverter circuits.
http://s807.photobucket.com/albums/yy352/budm/GATEWAY/
Make sure to use low ESR type caps.
Read my guide to understand how LCD monitor works.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
7/14/2011 3:14:24 AM • Gateway HD2201... • Answered on Jul 14, 2011
2answers
I have the gateway monitor model 2100. When i turn
email sprint6zoominternet.net
got all kinds fo fixes for this monitor
4/20/2011 12:45:05 PM • Gateway HD2201... • Answered on Apr 20, 2011
After re-bootng operrating syst.,(lost-original recovery
Welcome to Fixya
If you are referring to the Drivers and software of your computer then here's where to download all of these. Please click here.
Thank you for using Fixya! If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
4/15/2011 1:24:38 AM • Gateway HD2201... • Answered on Apr 15, 2011
Is there a special driver
If your monitor is a Gateway FHX2201Q, then your driver is at:
http://www.support.gateway.com/product/default.aspx?tab=1&modelId=3261
If your LCD monitor is an HD2200 series LCD monitor, then "generic PNP monitor" is it.
You can confirm by spending some time at the Gateway support site:
2/13/2011 6:19:03 AM • Gateway HD2201... • Answered on Feb 13, 2011
My monitor is shivering due to magnetic field tell
Solution for many "jittery" or "shaky" or "shivering" monitor problems...
Be sure there are no power AC cords in direct contact with or very close to the monitor cable anywhere along its entire length. If no help, be sure the monitor and monitor cable are not very close to a wall that may have an AC power lines running in it. Also, be sure that you are using a "grounded" (3 prong) power cord, that is is not plugged into a "2 prong" adapter that eliminates the ground ("earth") prong, and be sure that your power circuit that you are plugged in to is properly grounded.
12/8/2010 8:20:05 PM • Gateway HD2201... • Answered on Dec 08, 2010
I need a driver for
LCD monitor does not need driver but driver need for graphic chip set of your computer . For that you need to install graphic driver for your computer 's motherboard. You can download graphic driver from your computer manufecturer web sites.If it is assembeled computer then find your computer's motherboard info then you can download driver for your motherboard. Let me know if you need further assistance. Thanks for using FixYa.
9/16/2010 10:22:22 PM • Gateway HD2201... • Answered on Sep 16, 2010
Monitor turns on shows gateway logo, show DVI
The answer is yes. The monitor's backlight is failing...almost gone.
Sorry,
Marcus
9/15/2010 3:20:46 AM • Gateway HD2201... • Answered on Sep 15, 2010
Gateway HD2201 22" LCD Monitor Logo
45 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
need operation manuel 22inch gateway
  • Computers & Internet
