20 Most Recent Vision G1163801207 Webcam Questions & Answers
0answers
0answers
Ucom jpeg webcam
Be the first to answer 12/8/2013 2:31:35 PM • Vision... • Posted on Dec 08, 2013Be the first to answer
0answers
Driver download
Be the first to answer 11/7/2013 4:02:00 AM • Vision... • Posted on Nov 07, 2013Be the first to answer
0answers
0answers
I like to install my cam
1st You download Webcam Driver.I like to install my camAfter this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
3/18/2013 9:31:44 AM • Vision... • Answered on Mar 18, 2013
I lost my enet pc usb driver and now I want to install my webcam
1st You download Webcam Driver.I lost my enet pc usb driver and now I want to install my webcamAfter this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
2/2/2013 2:51:12 PM • Vision... • Answered on Feb 02, 2013
I need driver for pc instalation
If this is this for a webcam ? Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer If you still have no webcam installed Run the "Add a device"application, accessed by clicking on the "Start" button, opening the "Control Panel," and then double-clicking on "Add a device." The "Add a device" window will open and Windows will search for devices connected to your system but not installed. Click on the webcam name that shows in the search box and then click "Next." Choose whether you want Windows to search for the webcam device driver using Windows Update over the Internet, or if you'd prefer to have the device manager search for the driver using a disc supplied by your laptop manufacturer. Most drivers can be found on the system recovery disc included with your laptop, if you choose to add the driver from the provided disc. Place a check in the box next to your choice and then click "Next>" to continue. Wait while Windows searches from the driver using Windows Update, if this was your choice. An active Internet connection is required for Windows to successfully do this. Allow the computer to install the driver and then reboot the system for the webcam to become recognized by the system. Otherwise, you can use the system recovery disc or a driver downloaded directly from your laptop manufacturer to install the driver without using the Windows Update search feature. Open the CD/DVD-ROM drive and insert the system recovery disc, or place the driver downloaded from the manufacturer in an easily accessed file directory on your PC, such as on the desktop, or in your "My Documents" folder. Choose the option "Install the software automatically (Recommended)" in the "Add a device" application, and press "Next>" to begin searching for your webcam driver. The hardware wizard will search the system recovery disc and install the driver automatically. Press "Finish" to close the wizard and then reboot the computer to allow recognition of the webcam. Choose the option "Install the software manually" in order to browse to the driver location where you saved the driver and install it from there. Use the opened file manager and locate the driver. Click the "Next>" button to install the driver, then reboot the computer to add webcam functionality. Hope this helps.
1/25/2013 10:36:58 PM • Vision... • Answered on Jan 25, 2013
2answers
I have no driver jingjing
Try a driver finder program, might find the driver for your webcam.
12/13/2012 9:10:15 AM • Vision... • Answered on Dec 13, 2012
0answers
I lost my driver cd of my webcam plz send driver
i lost my driver cd of my web cam plz send driver of this model
8/22/2011 10:57:07 PM • Vision... • Answered on Aug 22, 2011
2answers
I lost my webcam driver
i have fujing webcam but lost the cdi also downloaded the driver but webcam no start what i do resolve free
8/22/2011 10:49:56 PM • Vision... • Answered on Aug 22, 2011
4answers
Vision G1163801207 Web Cam driver lost my cd
give me driver this veb. cam
8/22/2011 10:40:18 PM • Vision... • Answered on Aug 22, 2011
I need driver
Ok, you can download it from here
http://www.topshareware.com/g1163801207-webcam-install/downloads/1.htm
don;t frgot about my rank.))
5/30/2011 4:18:01 PM • Vision... • Answered on May 30, 2011
I lost my webcam cd
You will find the software to make your webcam run on http://www.visiongs.de/download.php
5/29/2011 5:46:09 PM • Vision... • Answered on May 29, 2011
Downlod
Here is a link on what I believe you are looking for Click Here
5/29/2011 9:23:33 AM • Vision... • Answered on May 29, 2011
Install web cam driver
Hi, possible currupt prog. Download latest update from WebCam makers? Reinstall.
If webcam still faulty, and is within warranty, don't waste your time, prove of purchase return to supplier refund or replacement.
5/24/2011 9:46:53 PM • Vision... • Answered on May 24, 2011
Vision G1163801207 web
that is my cam .but ihave no driver
5/9/2011 6:44:06 PM • Vision... • Answered on May 09, 2011
Vision G1163801207 Webcam Logo
117 questions posted
Top Vision Computers & Internet Experts
NOEL
NOEL
john h
ADMIN Andrew
ADMIN Andrew
Are you a Vision Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Vision Computers & Internet
Most Popular Question
no driver jingjing
  • Computers & Internet
