20 Most Recent
Insignia NS-LCD47HD-09 47 in. LCD TV Questions & Answers
Fuse location on ns-lcd47hd-09
Most modern TV sets don't usually have a separate fuse. Most have a safety cutout (Sometimes a fuse) soldered on to the main power inlet electronic board. Its inside the TV and will require the back to be taken off it. Make sure its unplugged before you do anything!
7/1/2015 4:06:11 AM •
Insignia...
Answered
on Jul 01, 2015
Why does the TV come on and flash "Please Wait"?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "
Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
4/11/2015 4:16:40 PM •
Insignia...
Answered
on Apr 11, 2015
Free tv repair advice
Unfortunately, without having a technician diagnosing the TV, we would be unable to advise what part(s) may be necessary for repair. I would recommend calling to schedule repairs. U.S. and Canada - 1-877-467-4289Mexico - 01-800-926-3000 We're here to answer your requests daily from 7 am - 12 am CT.
9/26/2014 3:45:36 PM •
Insignia...
Answered
on Sep 26, 2014
Red flashing power light blinking
These flashes are fault indications, and are called blinking codes. By the number of flashes occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. If you wish to get more details, check the site linked here
Selecting the view option, either to
Mosaic
/ Time slide, can be selected by the
drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
10/10/2013 9:42:15 AM •
Insignia...
Answered
on Oct 10, 2013
Insignia quit working after storm
Check the fuses on the power supply board first. They usually blow when you get a power surge. You may be able to replace them and get the TV running for a few dollars. If the fuses are good then the power supply board will be the issue. The main board should not be damaged because the surge has to go through the power supply board first.
8/22/2012 2:06:31 PM •
Insignia...
Answered
on Aug 22, 2012
Blu-ray player mode not supported
Is your TV 1080p? If the Blu-Ray is putting out 1080p and your TV only supports 720p/1080i then you will get a message like this. Try changing your settings to 720p while it is connected to a TV that does display correctly, then move it back to the 47 in LCD.
7/8/2012 8:30:45 PM •
Insignia...
Answered
on Jul 08, 2012
