For which remote exactly? Each manufacturer of programmable/learning remotes has their own code base and unique numbers for each code.
Asking for a code is like asking for the postcode/zip code of Acacia Avenue but without specifying the city and district.
Usually it is t-con bad. You can find it here:1-857-237-12 LJ94-02383 Sony KDL52XBR6 T-Con modulelink:http://www.ebay.com/itm/170994317153?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Hi, Its fixable problem like power supply board replacement will solve the problem. Unplug tv from wall socket for couple of minutes, replug back in and turn it On. If problem still exist then most likely power supply got fired and will be replaced, local tv repair shop will help you to replace power supply board. Thanks.
Visit the site named 'Electro-help' for more
details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. You can also
click the [Home] tab to see the latest updates. It will make search
easy. There are more than 1350 posts to different brand TVs now. Pull up older
posts there.
Well, if the power supply is in good working order, you will need to verify that the proper voltages are getting to the main board. If the main board is getting the proper voltages, I would bet you have a defective main board. The video and audio signals are generated on the main board. Expect to pay $100-$150 for a replacement main board.
OCP ( Over Current Protection ) 02Main power supply regulator board might need replacement. Visit the site named 'Electro-help' for
more details.Click this link.View it in'Flip card' option, which can be selected from the drop down box
menu by the [Sidebar] tag, at the top left corner of the display
window.It will make search easy. There
are more than 900 posts to different brand TVs now.
Take it to a shop for a estimate unless you want to start buying circuit boards and replacing them to see if it is a board or the display panel itself.
There are some components on either the driver board or in the panel itself that have become thermo sensitive. This would entail changing a board or the panel itself. These are not supported or usually possible to service at the component level. The circuit boards are in multi layers, and the components are mostly surface mount. Get an estimate from the factory service before committing to service the set. It may be more feasible to replace the set than to fix it. This usually the case with this type of technology. Jerry G.
That problem is cause of faulty power supply board..look at the capacitors if bulged then try to replace it..Watch this video to learn more about capacitors:If you have soldering skills its better to buy a new power supply board online...
