20 Most Recent
Samsung HL67A750 67 in. TV Questions & Answers
Check fan 3
One among the cooling fan is out of order. Check and replace it. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
How do I replace Fan #3 on a Samsung HL67A750A1FXZA tv?
A thorough cleaning of the fans and heat sinks should be performed every three mmonths or so, depending on how dusty your home is, or if you have pets.These fans 'should' last as long as the set does...but they won't. Just try and run a floor model cooling fan in your house and see if you can get 5000 hours out of it! Not gonna happen.The fans are relatively easy to replaced once the rear cover is removed. They either snap into place on the chassis, or have a couple screws. The wiring is a simple plug. Don't yank on it!!! There may be a small catch tab release you'll have to satisfy before you can unplug it. And NEVER insert of remove these plugs any way except straight in and straight out.Hope this helps some of you DYI-ers out there. I should also say that if you aren't comfortable working with static sentive, high voltage electronics, you should leave the job to a professional.
