20 Most Recent Toshiba 32AV502U 31.5 in. LCD HDTV Questions & Answers
2answers
The tv does not turn on when plugged in. I do not
your TV is having a power problem. The power supply board is defective that's why the TV won't power up. Its receiving power but it cannot transfer the current to the necessary part of the TV because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the TV might not come on.
This may have occurred as a result of power surge/irregular power supply or excess power that may have entered into the TV previously.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
I wish you good luck.
1/11/2019 12:57:03 AM • Toshiba 32AV502U... • Answered on Jan 11, 2019
Trouble with HDMI cable from Kindle Fire HD to model 32AV502U
Faulty HDMI port on your kindle. Best option return to manufacture.
12/13/2017 6:53:08 AM • Toshiba 32AV502U... • Answered on Dec 13, 2017
TV Ears won't work with new Toshiba tv
wrong ports for antenna operation you need antenna in ports
11/3/2017 5:10:56 AM • Toshiba 32AV502U... • Answered on Nov 03, 2017
Tv is not responding
Do a HARD reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ if this do not help, Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked above. Pull up older posts. In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
7/2/2017 2:25:13 PM • Toshiba 32AV502U... • Answered on Jul 02, 2017
Tv will not turn on
2/23/2016 4:46:40 PM • Toshiba 32AV502U... • Answered on Feb 23, 2016
Great picture,but sound is (machine gunning)
Bad connector. change out the audio cables and this should take care of it. Even if they are new you will want to try this...they go bad all the time. If that is not it the you need to verify it is not the source. Do this by trying other sources and see if you can duplicate the problem. If you can do this with new cables then it is your speakers or connection on TV.
11/11/2015 4:30:24 AM • Toshiba 32AV502U... • Answered on Nov 11, 2015
TV won't power up. This model has lost a power supply before. how do I verify this is the problem and replace the faulty component?
Hi Dave, Troubleshooting circuit boards to the component level has become a bit harder due to the availability of semiconductors. I would suggest to measure all the voltages from the power supply at P802 and P803. Let me know if you require further assistance or I can send you the service manual if need be.
9/13/2015 4:51:36 PM • Toshiba 32AV502U... • Answered on Sep 13, 2015
Program a universal remote control
There is a common procedure with all remotes, you need to look up your TV code, and most have directions on how to sequence the code to your TV, not hard at all. FREE-PPV.com
4/21/2015 9:55:07 PM • Toshiba 32AV502U... • Answered on Apr 21, 2015
BROCKEN SCREEN
This one of those things that will cost almost what a new television does. When buying new if you have a Visa card, use that it doubles the original warranty, and for $60.00 or $70.00 they will give you an extended warraty of four years!!!!!!
3/29/2014 6:29:24 PM • Toshiba 32AV502U... • Answered on Mar 29, 2014
I notice that the TV has two HDMI cable slots on the back. Can a movie be streamed directly to the TV via Netflix?
If you get netflix thru a Roku playeror other brand of streaming device..yes
1/6/2014 6:55:19 AM • Toshiba 32AV502U... • Answered on Jan 06, 2014
MY TOSHIBA LCD TV SCREEN IS CRACKED DOES IT HAVE A
Hi Erika, If your LCD is cracked, you will need to unfortunately replace the entire LCD. Simply putting a screen protector (which is just a thin film) will not stop the crack from getting worse. There is unfortunately no magical way to fix your screen other than simply replacing the LCD panel itself, which is totally doable. Many electronics repair shops can fix your TV pretty easily. In some cases, you can even mail it into Toshiba.
11/21/2013 3:54:37 AM • Toshiba 32AV502U... • Answered on Nov 21, 2013
Toshiba lcd tv 32" making noise by speaker
test this steps and fix it. God bless youLine noise is feeding in from the AC line. Use an AC liner filter to block the line noise. RF (radio frequency) interference is being picked up by the power line or wiring. Remove sources of RF interference, such as fluorescent lighting or wireless devices not designed to work with audio/video equipment. Wires between the components are on top of one of the components; the transformers are causing RF interference. Be sure that wiring goes behind the components rather than on top or between components. If there is an equalizer in use, there could be a ground loop. Ground loops can be resolved by installing GLI's (ground loop isolators) on the cables connecting to the equalizer.
7/25/2013 11:40:12 PM • Toshiba 32AV502U... • Answered on Jul 25, 2013
No sound on my 32av52r toshiba
Just a few things that are simple to check:If has a headphone jack does it have sound?Look in menu to see speakers are not set to OFF or to external.Does it have sound with a DVD etc. connected to a rear audio/video input?
12/23/2012 3:22:29 PM • Toshiba 32AV502U... • Answered on Dec 23, 2012
MY SAMSUNG LCD TV MODEL LNS4695DX HAS A SNOWY PICTURE
check the picture settings in the menu... someone may have been fiddling with them
12/4/2012 12:40:04 AM • Toshiba 32AV502U... • Answered on Dec 04, 2012
Screen Flicker/Speaker Pop on one HDMI
Look for loose contacts in jacks, sockets, cables. Look for loose contacts in power outlet.
8/3/2012 4:56:12 PM • Toshiba 32AV502U... • Answered on Aug 03, 2012
Toshiba 32AV502U 31.5 in. LCD HDTV Logo
62 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
samsung lcd tv model lns4695dx snowy
  • Televison & Video
