20 Most Recent
Emerson CR202EM9 TV Questions & Answers
Cr202em8 universal remote code
If you go to Big Lots and purchase their 4 device RCA Universal Remote, the code 10171 will completely control your Emerson SDTV. All functions including Inputs will work with that particular remote. The beauty is it's only 8 bucks.
Have Emerson TV and lost original remote. Direct
There are control buttons on the side of the tv. Usually just on/off, volume, channel and menu. Go it menu using these buttons to navigate. Reset tv to default settings or sometimes called factory settings. This should get colour back. Download or read instructions on your remote and reprogram. Sometimes with modern universal remotes you need to program them through your PC with a specific application downloaded from remote manufacturer.
How to connect dvd with tv
You would connect the outgoing port on the DVD to the input port on the back of the TV using either RCA cables or an HDMI cable.
Hello a trying to connect my emerson tv with model cr202em9 using a comcast remote. how do i do that
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "
brand name" to your device; in the "
Search box at the top right of the display window" to get gathered related posts.
My remote will not work
try to change the batteries in it, if not works, try to take it apart, and find where is the break in the circuit.
No remote and cant get to video
You are gonna have to get a universal remote. It isn't expensive if you don't want it to be. I bought one for $7 and it was easy to set up with auto code search
Wont stop scanning
If only scanning in one direction (up or down channels) the button associated with that direction has a tiny switch under it which is stuck or bad----I have seen this before and about the only fix is to gain access to that switch and disable it (two leads to unsolder) to take it out of the circuit----remote will still work.
Speaker goes on and off
Check to make sure there are no loose connections going from the speaker to the PCB as well as checking the speaker soldering if they used solder or quick connectors. If there isn't I would then start testing components in the audio section of the PCB. You can also test your speaker with a multimeter but I'm thinking the speaker might not be the problem.
No sound when tv ison
not really a problem, look to see setting in audio menu are all correct, only possible thing which is really rare would be the tuner in the set which does process audio but Las Vegas odds would say no way.
