20 Most Recent Samsung DV316LES Electric Dryer Questions & Answers
My dryer's barrel will not turn. I have
Hello Mwagner, sounds like the Idler bearing pulley assembly has come loose from the belt. It's job is to keep tension on the belt so the motor is able to turn the dryer drum. By watching some videos online it seems that alot of teardown is required to get to the part you need to inspect and or replace. Here is a link for you to look at that might help you. Samsung Dryer Idler Pulley Roller Replacement DC97 07509B
5/4/2017 7:57:03 AM • Samsung DV316LES... • Answered on May 04, 2017
2answers
Dryer runs, but doesnt heat. Every now and then will heat up for a few minutes , then stops.
first would check ur venting to the wall and into and out of the machine? the blower? is it blowing hard or soft at the back exhaUST? IF THIS IS GAS then I would check the flame sensor, igniter and more than likely the safety valve and coils? I suspect the coils are not putting out enough pressure consistantly to keep the flame lit? check with an Ohm meter not just for continuity but for an OHMS rating as per ur schematic. it should be putting out a certain amount of ohms if the coils are bad u will get intermittent heat? the igniter and flame sensor will go on and off over and over.
4/25/2015 5:14:31 PM • Samsung DV316LES... • Answered on Apr 25, 2015
How do I check Thermistor resistance?
You would need to disconnect power to dryer locate thermistor remove one lead from thermistor and check resistance with an ohm meter. there should be a tec sheet somewhere in the dryer and this should tell you what the resistance should be.
8/22/2014 1:08:54 PM • Samsung DV316LES... • Answered on Aug 22, 2014
Samsung dryer #DV316les/xaa overheated and now will not work?
Thermal fuse blown on heating element cage.
8/10/2014 1:49:01 PM • Samsung DV316LES... • Answered on Aug 10, 2014
My Samsung dryer model# DV316les/xaa overheated due to pluged vent, now it will not run?
could have a reset button on the back.
8/10/2014 4:15:50 AM • Samsung DV316LES... • Answered on Aug 10, 2014
Whirpool LGR8620PW0 not heating and smells like burning
answers.us.samsung.com/.../samsung-7...electric-dryer.../questions.htm
7/1/2014 3:16:49 AM • Samsung DV316LES... • Answered on Jul 01, 2014
Dryer drum beldt will not tighen
Check to make sure that it goes around your idler pully correctly. It can be a pain some times. If you are sure it is correct. I have been sold wrong belts in the past more than once.http://www.on-timeappliance.com/dryerrepair.html
3/28/2012 3:56:57 PM • Samsung DV316LES... • Answered on Mar 28, 2012
Dryer does not heat and smells like something is
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
1/15/2011 4:49:11 AM • Samsung DV316LES... • Answered on Jan 15, 2011
Dryer does not turn. Will humm and then shut off.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
12/23/2010 4:38:40 AM • Samsung DV316LES... • Answered on Dec 23, 2010
The high limit thermal switch on heater burns out.
There are two thermostats, a 'limit' or 'operating' thermostat which turns the heating element on and off, and a 'high limit' or 'safety' thermostat which oversees the 'operating' thermostat by opening and removing power to the heating element when the upper limit temperature is reached. Basically, the only difference between these two are the temperature ratings. The 'high limit' is higher than the 'operating' thermostat. The thermal fuse is the last resort protection.
First and foremost, you must know that every inch of your exhaust vent pipe is clean.
Usually, a bimetallic limit switch will degenerate in the direction of too low of a temperature range because as the parts wear out inside, the mechanical tolerance widens (the tiny rod that pushes the contacts together gets shorter).
The high limit thermostat is by the thermal fuse. The operating thermostat is in the blower housing.
Check the fan impeller for broken vanes and lint. The impeller is directly coupled to the motor and should not turn without the motor. The fan housing and ducting should be free of excess lint.
Good luck.
5/2/2010 2:16:37 AM • Samsung DV316LES... • Answered on May 02, 2010
2answers
My Samsung front load
Hi Jolene...You could have numerous problems causing your dryer not to heat.
I included some things to try and locate the problem part.
You can buy the parts needed on the following websites or numerous other website that sell parts.
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks.
If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the
wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed
component. The switch is inside the dryer main housing near the door frame.
Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Check for continuity you should have none with door open, and should have a reading when closed.
If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause
heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the
thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's
plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me...Hunter
11/2/2023 8:38:09 PM • Samsung Dryers • Answered on Nov 02, 2023
My drum dryer is making noise when spinning
Your best option is to get a technician to look at it and quote for a repair. A squeaky drum could be anything from the dryer not positioned level, a worn drive belt slipping, a worn out drum bearing or worn motor.
10/24/2023 7:37:54 AM • Samsung Dryers • Answered on Oct 24, 2023
Samsung Dryer dv42h5200ep/a3 Stuck On Cooling
According to a post on applianceblog.com, this issue could be caused by a blocked vent or vent hose, which can trigger the HE error. You can start by checking if the vent and vent hose are not blocked. If that's not the issue, you can try measuring the voltage across RY5, RY6, and RY7 on the main power board during a normal dry cycle. If there is no voltage, you may need to replace the control panel . If you're looking for more information on troubleshooting your Samsung dryer, appliancepartspros.com has a comprehensive guide that lists common symptoms and their causes for your model .
10/22/2023 8:26:55 PM • Samsung Dryers • Answered on Oct 22, 2023
Samsung error code DE can't clear it?
Since you had a garment get caught in the door, check the hinges and the door latch and striker. Something could be damaged, bent, loose or deformed. You may be able straighten the part or replace the specific part to get the door to close properly. A problem with the door switch or the wiring is also possible. However, I wouldn't check that the switch is not providing the locked signal to the control board until the door closes with the correct alignment of the latch. If you do need to check the wiring, see https://fleetappliance.com/dryer-repair/how-to-fix-samsung-dryer-error-code-de/ for accessing the lock mechanism. I hope this helps. For further information, including a check for a parts list, please add a comment with the model number of your dryer. Cindy Wells
10/19/2023 9:47:30 PM • Samsung Dryers • Answered on Oct 19, 2023
Samsung Dryer DV203AEW/XAC blowing fuses and seemingly too hot?
A newer element will only cause it to run too hot if it was a hotter element (more kilowatts) than the old one. Over heating problems are usually caused by poor air flow. If you got as far as the element you must have cleaned all the INTERNAL ductwork and the fan itself? EXTERNALLY, the exhaust hose should be as short as possible and without bends. Also check the duct through the wall, and check that the louvres on the outside are opening fully when the dryer is running. Birds love to make nests in there unless you have a cage on the outer vent. If it is 7 years old, it might just be time to invest in a new one. Having said that, my Whirlpool is 15 years old. ..
10/4/2023 4:04:50 PM • Samsung Dryers • Answered on Oct 04, 2023
Samsung DV316LES Electric Dryer Logo
12 questions posted
Top Samsung Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
View Most Popular
Samsung Dryers
  • Samsung Dryers
Most Popular Question
high limit thermal switch heater burns
  • Dryers
