20 Most Recent
Amana NGD7200TW Gas Dryer Questions & Answers
Dryer drum off balance
Put a construction level on top of dryer, use a 3/8 '' wrench to adjust the bottom feet as needed, to bring the level bubble to the middle.
What is error code ts
Thermistor is bad. Call the Company, they should send you a new one. 1-800-555-1212, toll free directory for Company phone numbers.
Why does the dryer make a noise and shut off early
Dryers are pretty simple when it comes to shutting down. It is either over heating or out of balance from a bad belt. I would start but taking off the vent and doing a thorough cleaning of the entire air path and vent coming off the back of the dryer.
Amana front load dryer model NGD7200TW wont heat
Amana? Huh, I thought they only made Frigerators!? OK, You have to locate the Four heat sensors on your dryer and run a voltage meter through them. You put the meter on just the volume icon so that when you touch the two leads it makes Contact and emits a sound. That means it is a good circut. You have to test each one of these sensors to see which one is bad. If you need further help, reach me via phone at
https://www.6ya.com/expert/steven_b77d19396bfe2249
Dryer wont heat
You probably have a bad sensor that tells the gas to stay on after you have hit the selection of your dry time fairly not to expensive contact sears parts
