That might be due to having a clogged filter chute. Go to google search and hunt roper dryer no heat, I made a video Also here is a pictoral I made to show you how to clean that puppy. It is a tried and true design over fifty years old. Paw Paw's Fab Roper dryer tune up If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Basketball is one of the most popular and exciting sports in the world. It is a game that requires skill, speed, strategy, and teamwork. But what if you don't have a court, a hoop, or a ball? What if you want to play basketball anytime, anywhere, and with anyone? Well, you can do that with basketball stars, a fun and challenging online multiplayer basketball game that you can play on your browser or mobile device.
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Have you ever cleaned it out? If not, that is the most common problem with dryers. It can't breathe and takes multiple cycles to dry the clothes. Unplug the dryer and pull it out. Disconnect the vent from the back of the dryer. Clean out lint from dryer and vent. Take the vent outside if you have to and blow it out with air compressor, if you can. Now check the other end of the vent outside at the vent cap. Clean it out and make sure the vent cap flap is not stuck closed. After reassembling vent, turn on dryer and check for heat at outside vent. You also may need to clean it out more if lint has traveled down the vent. Also, clean out your lint filter religiously for more efficient drying. Those are the easy things to look for and fix on your own. If it still does not improve drying, you made need a repairman to trouble shoot it. Good luck!
What is the model number?Exactly which parts did you check?Also, check the breakers. The breakers are 220 and one of them may have thrown not allowing it to heat but the dryer will run.
Clean the lint out of the pipe that goes out side, also the grate on the outside, If that dosent do it take the back off and see where the lint comes out, take that apart and clean the lint out. I have had this problem before and just recently. The dryer has a saftey fuse, when the dryer gets too hot to shut off, thats why your clothes are not drying. 1st try the pipe that goes outside including the end(outside).
