20 Most Recent
Samsung DV218AG Gas Dryer Questions & Answers
I have taken a Samsung Gas Dryer DV218AG to
it seems like your transformer has only converted the power source to the approximate voltage but the frequency is off. Please take a picture of the error and show it to the store clerk where you purchased the transformer so that they can find a transformer that gives both the proper voltage and frequency.
Thank you.
Samsung gas dryer takes to long to dry
long drying is usually due to a bad venting set up or a bad moister
sensor, a bad cycling thermostat? it is constantly
running though right? if not a bad safety valve and coils can causit to go off and on and not dry well.
Is kenmore made by whirlpool
Hello, the simple answer is yes, most Kenmore appliances are made my wirlpool and then the Kenmore logo is attached. Hope this helps. Mike
The drum stopped spinning on
Welcome to FixYa.
Yes it does have a belt. I'd say your assessment is almost bang on, based on your description and my experience. I've seen this many, many times...though the belt usually doesn't break it just comes off. Very common for Samsung dryers for whatever reason.
**Unplug the unit before proceeding...safety first**...
The good news is if it's accessible from the back you can simply remove the small panel around the exhaust tube as shown here,
if it's not you'll need to go from the front...do-able just a little more involved, let me know.
Once in the back the belt should look like this when routed properly, with the "V" grooves towards the drum and motor pulley.
i.e.
Hope that moves you forward...or even better, to the finish line, lol.
Let me know what you find. If this is something you think is not within' your scope of expertise please call a pro.
I will try to help in any manner I can of course as well. Good luck.
Regards,
Macmarkus :)
Drum will not rotate model
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The
Dryer is not TurningDryer Repair - The
dryer will not startheatman101
