20 Most Recent
LG DLE2516 Electric Dryer Questions & Answers
Check dryer vent light comes on
check the back venting system and the front system still can be clogged by particals getting past the screen look inside the fornt system with screen out.
Filter light
Could you please describe the problem you are having a little better?
Dryer runs normal but with
pull
off right access port cover, look in and left for thermostat hanging
down off of exhaust tube. Press button between the two wires going to
thermostat. It is a 3 minute operation if you can get to the right
side access port.
My LG electric dryer is not blowing any heat
Have you checked your circuit breakers to make sure they have tripped??Look at the junction box behind the dryer where the power cord connects to the electrical system of the dryer. Open the panel and make sure that the connection is clean and tight. If it has any burn marks, you will need to replace the whole wire harness under LG's repair policy.If these problems are eliminated, then you may have a problem inside the heating element or it's high limit switch which is inside the dryer and require disassembly.Hope this helps.
