20 Most Recent Seiko Mantel Clock Questions & Answers
Turn the minute hand until the 16 westminster chime operate and then the hour strikes. Remove the minute hand and simple put it back on at the 12 o-clock position. The chimes should now be in sync.
Fred
Seiko Mantel... | Answered on Jul 23, 2019
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Seiko Mantel... | Answered on Jan 09, 2019
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
Seiko Mantel... | Answered on Mar 01, 2017
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Seiko Mantel... | Answered on Jan 29, 2017
http://usedclockparts.com/8-clock-movement-repairs/14-fix-a-clock-that-gongs-wrong
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 6 o'clock and replace your dial nut and you are all set.
Seiko Mantel... | Answered on Jan 28, 2017
You may need to try to repair or replace the quartz movement, this link will help you out.
http://usedclockparts.com/14-clocks/clock-videos/126-quartz-battery-operated-clock-movement-repair
Seiko Mantel... | Answered on Jan 25, 2017
When was the last time it was serviced? The movement probably needs a good cleaning and/or oiling.
http://usedclockparts.com/8-clock-movement-repairs/39-how-to-easily-clean-and-or-fix-your-clock-movement
Seiko Mantel... | Answered on Dec 30, 2016
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
Seiko Mantel... | Answered on Dec 16, 2016
Seiko Mantel... | Answered on Oct 03, 2016
Home Logo
131 questions posted
Top Seiko Home Experts
Janelle Schoonover
Janelle Schoonover
Jerry Greenberg
Jerry Greenberg
k24674
Are you a Seiko Home Expert? Answer questions, earn points and help others
View Most Popular
Seiko Home
  • Seiko Home
Most Popular Question
looking manual seiko mantel clock
  • Home
