20 Most Recent
Nokia 6124 - 100 Minutes any time, any Network Cell Phone Questions & Answers
Code for NOKIA MOBILE.
WHEN YOU WANT TO BUY A NOKIA MOBILE AND YOU ARE DOUT FULL ABOUT THE PHONE THAT IT IS ORGINAL OR NOT THENUSE THE CODE IF THE DETAILS OF PHONE APPARE ON THE SCREEN AFTER PUTTING THE CODE THEN ITS IS ORGINAL AND IF IT DOES NOT SHOW ANY DETAILS THE THE PHONE IS NOT ORGINAL.
THE CODE IS *hash0000*hash
Restriction code for Nokia 2690
It is normally recommended you Don't post your IMEI on websites. It is a security code for that phone.
Usually the IMEI number has to be reset by your network provider. It normally cannot be done directly from the handset. Did the handset accept the new sim card. Some handsets can be locked to a specific network and changing network can stop your phone from working.
Nokia 2730C-1. can I unlock the network
If the phone was not used 2012, the phone number and phone have been deactivated from the network you used to pay for service. You need to set up a new contract as they expire after about 2 years of inactivity.
Backup contacts from broken nokia 2730c-1
Yes, there is a solution to backup contacts from your broken Nokia 2730c-1.
Before flashing the phone, one option is to try using Nokia Suite software on your computer to connect to the phone and backup the contacts. Another option is to remove the SIM card from the phone and insert it into a different phone to access and backup the contacts. You can also try using third-party software or services that specialize in extracting data from broken phones. It's important to act quickly to ensure you don't lose any important numbers. Good luck!
Help me Forget nokia 1680c 2 .how fo do it? please
What do you mean by a 'restriction code'? If it is your password you might have to do a 'factory reset' on your phone.
If it has been locked with the IMEI code you will need to contact your network supplier to get them to unlock the handset.
