20 Most Recent Seiko Melodies in Motion Clock Questions & Answers
Seiko Melodies in Motion Wall Clock QXM123BRH. It works fine except it does not function on the hour as it is suppose to-demo works fine.
Question edited for clarity, 'make model (what it is)'. Question moved from Video Consoles to make model category. I am having difficulty finding a manual, but as I understand it there is a switch for you can switch off chimes and movement at night when you go to bed. https://www.google.com/search?q=Seiko+qxm123brh+instructions Ask Seiko Support direct.. https://www.seikoclocksusa.com/support/manuals/ ..
1/7/2024 3:10:22 AM • Seiko Melodies... • Answered on Jan 07, 2024
Seiko Octagon desk clock model QEJ105G: I put a new battery in and it still doesn't work.
Question edited for clarity and spelling of 'Octagon'. Question moved from Motorcycles! No manual and nothing about this button, but try pushing it a second time as it may toggle. https://www.google.com/search?q=Seiko+Octagon+QEJ105G+manual ..
1/29/2023 4:43:40 AM • Seiko Melodies... • Answered on Jan 29, 2023
Where is the light sensor?
12/22/2022 3:01:48 PM • Seiko Melodies... • Answered on Dec 22, 2022
I have a Seiko Melodies
I'm not sure if you still have your clock but I just fixed mine, same issues as yours, if you open the back up and there are two black little boxes, the left box controls the face opening and closing, take the two screws off the opposite corners, the white independent wheel has worn the whole larger, so I glued like a little brass piece yo ouch the stem of the wheel back in the original whole just make sure you don't get glue in stem, the piece you glue should be glued in the opposite side, we used gorilla glue, Just a small dab
6/21/2022 12:23:07 PM • Seiko Melodies... • Answered on Jun 21, 2022
2answers
My seiko musical wall clock
To test your Seiko Melodies in Motion Clock:
1) Check the volume knob in the back of the Seiko clock to make sure the volume has not been adjusted all the way down.
2) Make sure the on / off switch is set to on.
3) If it is extremely dark in the room, the clock will not play, it has a light sensor. Make sure the room is well lit.
4) There are separate batteries usually that operate the clock and the music. Change the batteries paying special attention to any acid / corrosion caused by old batteries. Clean out any acid and it should play. Also, be careful not to touch the positive or negative contacts on the new batteries, as this could inhibit proper connection.
If you have done each step above and it is still not operating, your clock is defective. Contact Seiko Service Center directly at: 800-722-4452 extension 3.
If you have had the clock less than a year, and it was purchased from an authorized dealer, it is under warranty, and any repairs will be free. Otherwise, there may be a charge for the repair.
1/18/2022 3:45:52 PM • Seiko Melodies... • Answered on Jan 18, 2022
Why does my Seiko only play the intro to a melody?
Mine does the same thing. It plays the intro and starts the melody then goes back to the intro. I've changed batteries. If I move the song selection switch I can get it to work but only for a while.
4/22/2021 2:19:38 PM • Seiko Melodies... • Answered on Apr 22, 2021
Seiko wall clockNeed battery cover and repairs Model #QXM139SRH
I sent my clock off to Seiko for repair, useless, they said it was in the circuitry. I had them send my clock back. I ordered a new gear box $2.00, replaced that, it will work as long as it's flat. If you look you can see how the clock cycles I made sure it was "locked" in (you can hand force it) then I removed one of the gears so it doesn't cycle down but stays in the up position at all times. Music plays, lights go, just no motion now. Call Seiko for replacement battery cover.
2/14/2021 12:53:31 AM • Seiko Melodies... • Answered on Feb 14, 2021
Seiko hi fi 7 melodies clock won't play or light up
I would take it to a clock repair shop. UsedClockParts.com
1/29/2017 10:25:57 PM • Seiko Melodies... • Answered on Jan 29, 2017
Seiko wall clock pendulum not working
When was the last time it was serviced? The movement probably needs a good cleaning and/or oiling. UsedClockParts.com
1/29/2017 10:22:32 PM • Seiko Melodies... • Answered on Jan 29, 2017
How do i set my seiko wall clock
1/29/2017 10:19:09 PM • Seiko Melodies... • Answered on Jan 29, 2017
Why will my clockl no longer play song or move
When was the last time it was serviced? The movement probably needs a good cleaning and/or oiling UsedClockParts.com
1/29/2017 10:12:16 PM • Seiko Melodies... • Answered on Jan 29, 2017
Will not turn time piece but will keep time
I would take it to a clock repair shop. UsedClockparts.com
1/25/2017 6:35:40 AM • Seiko Melodies... • Answered on Jan 25, 2017
Stopped keeping time after one year. Replaced "D" batteries, but still does not work.
You may need to try to repair or replace the quartz movement, this link will help you out. http://usedclockparts.com/14-clocks/clock-videos/126-quartz-battery-operated-clock-movement-repair
1/25/2017 6:34:25 AM • Seiko Melodies... • Answered on Jan 25, 2017
Seiko Melodies in Motion does not change tunes
1/25/2017 6:33:29 AM • Seiko Melodies... • Answered on Jan 25, 2017
Batteries leaked
You are probably better off just replacing the movement, you can find them at timesavers.com. UsedClockparts.com
12/30/2016 7:42:52 PM • Seiko Melodies... • Answered on Dec 30, 2016
I have a Seiko special collector's edition HKAB04
You may need to try and repair the quartz movement, this link will help you out. http://usedclockparts.com/14-clocks/clock-videos/126-quartz-battery-operated-clock-movement-repair
10/3/2016 9:37:52 PM • Seiko Melodies... • Answered on Oct 03, 2016
Change the glass front to clock
You can find replacement glass at timesavers.com. UsedClockparts.com
10/2/2016 11:43:14 PM • Seiko Melodies... • Answered on Oct 02, 2016
Seiko Melodies in Motion Clock Logo
101 questions posted
Top Seiko Home Experts
ZJ Limited
ZJ Limited
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Seiko Home Expert? Answer questions, earn points and help others
View Most Popular
Seiko Home
  • Seiko Home
Most Popular Question
change melodies
  • Home
